Old 04-22-2018, 08:27 AM
The Weed's Avatar
The Weed The Weed is offline
Default Project Mix I/O...
Is anyone successfully running PT 2018 on Windows 10 with a Project Mix I/O?
A friend is stuck in Apple Catch 22 update land; he wants to update his OS so he can use PT 2018.4 HD, but there are no drivers for any new OS X as Apple gave up on FireWire several years ago. He can't afford a new computer and interface - struggling audio engineer. The M-Audio forum has a few people doing so successfully with Windows 10 and PT 12 using the Windows 7 drivers, but wanted to check here too.
TIA
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 04-30-2018, 08:40 AM
lemix's Avatar
lemix lemix is offline
Default Re: Project Mix I/O...
What Mac Bruce ?? They all have Thunderbolt ports since about...2011 ??
Wouldn't a TB > FW adapter work ??
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
Old 04-30-2018, 08:46 AM
The Weed's Avatar
I haven't been in touch with him recently, so can't answer that. I believe it has to do with FireWire drivers and the OS X version he needs to run PT 2018, so I have to assume he doesn't have any TB ports to use or he needs a driver even though he has a TB port to use. He did mention he found someone on the web who claims to have written new drivers for the Project Mix.
SonoBus
Create New Project - There was an error posting the project. descendant Pro Tools | Intro Discussion 13 04-24-2016 06:35 PM
New Project's saving to existing Project's??? larsongs Pro Tools 10 9 04-13-2015 02:29 PM
making a project sound like a project skwad Tips & Tricks 2 01-25-2007 05:54 AM
Case/Project box for MBox Project? RMcFarland 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 02-23-2004 05:31 PM
PT project and G4? picktom General Discussion 0 06-12-2002 10:55 AM
