Old 12-07-2002, 12:53 AM
DigiTechSupt's Avatar
Default ASIO beta news
Hello ASIO users. We are getting close to closing down bug submissions on the next ASIO beta driver.
If you have any bugs and/or behavior to report, please do so before Dec. 13, at which time no more bug submissions will be accepted.
Reporting Bugs. Please go to the ASIO download page on the Digi site. Scroll to the bottom of the page where you'll find this information. Thanks.
This is a beta release, so there will be bugs. If you have encountered a bug please email a detailed description of the bug with the following information to [email protected]
Please Include:
  1. <font size="2" face="Verdana, Arial">The ASIO program you were using when the bug was found
  2. <font size="2" face="Verdana, Arial">The version of the Program (e.g. Acid 4.0)
  3. <font size="2" face="Verdana, Arial">Your ASIO control panel settings (e.g. 256 buffer size)
  4. <font size="2" face="Verdana, Arial">Digidesign hardware used (e.g. 002)
  5. <font size="2" face="Verdana, Arial">Summary of your computer system (e.g. P4, 2.4Ghz, 512MB RAM, Intel 845E chipset, 7200 RPM dedicated audio drive, etc.)
  6. <font size="2" face="Verdana, Arial">Description of Bug.
<font size="2" face="Verdana, Arial">Please be concise. All information must be included in order for us to address the bug.
The deadline for new bugs to be considered for the next beta 2 release of the ASIO driver is December 13th. After the beta 2 release, there will not be another ASIO driver posted for approximately 6 months.
Check back on this same page for new versions of the Digidesign ASIO driver with bug fixes:
www.digidesign.com/download/asio
Tom S.
Digidesign Customer Service
Avid Audio Tech Support
Support FAQ
Old 12-09-2002, 08:11 AM
Default Re: ASIO beta news
Bump.
Support FAQ
Old 12-09-2002, 08:57 AM
Rock_Artist Rock_Artist is offline
It's more questions as you mention 6 months with no update [img]images/icons/frown.gif[/img] .
Latency?
Is there will be improve for AudiomediaIII and Digi002.
currently I wasn't able to get both below 512samples [img]images/icons/frown.gif[/img] .
multiple hardware?
is there chance i'll be able 2 use 2 digi cards in asio.
i have now the mbox and am3 both on the same machine but they would work seperalty.
Thanks. [img]images/icons/smile.gif[/img]
Just wanna do music,
RA.
Old 03-30-2004, 05:54 PM
efernan1 efernan1 is offline
BUMP!!!
Audiomedia III's ASIO driver can't be set to 128 or 256 samples buffer!!!!!
Please, any solution/fix?
TIA
Old 03-31-2004, 08:51 AM
BUMP again!
Old 03-31-2004, 10:02 AM
The AM3 is an EOL product.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 03-31-2004, 03:18 PM
Hmm... EOL????
If you're trying to say me that it's not longer supported, sorry to say but you're completely wrong...Pro Tools LE v6.1.1 is completely, absolutely supported by Digidesign, check the docs.
Pro Tools LE is working just fine, in any buffer setting: 128, 256, 512, 1024. The problem is with the ASIO driver. The 128 and 256 samples buffer setting aren't working. The options are in there, but when you select any of these two, it reverts back to 512 samples. This is a design bug and other people reported it.
Thanks!
Old 03-31-2004, 06:02 PM
lemix's Avatar
lemix lemix is offline
Hi there efernan1 ,
Just chill a bit dude...when Rail said "EOL" I think he meant > End Of Line Product.
It's like many people still on Windows 98, and NT but MS has pulled future support for them...
Obviously the 001 is still supported under LE 6.xx, many users of this board using it !
As far as the ASIO issue goes...I too wish it was was fully resolved, finally...
cheers,
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
Old 03-31-2004, 07:58 PM
Hi again,
Sorry if I sounded negative. The thing is: Audiomedia III is supported up to date, but up to date ASIO drivers doesn't work correctly. That's all.
I just want a solution from Digidesign.
Thanks!
Old 04-05-2004, 09:38 AM
Escape Escape is offline
Hi
I use 002rack with cubase sx 1.06 and it works ok but when i tried sx2.01 the vst synths didn't work.I could't hear a sound but after a while it started to work and then i changed a midi channel but it stopped again,no signal,nothing.Audio works fine,i can record and playback just fine but the midi has problems.
I use 002rack,athlon 2600,1gig memory kingston,2 hard disks western digital 120 and 80,firewire adaptec,ati 9200,asus A7V600.
Thanks
ASIO Good News! TwinSnakes007 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-17-2009 08:28 PM
ASIO Driver news! ptrbas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-14-2003 02:19 PM
ASIO Beta 5.3.3b2 and WaveLab DaveJDoc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-15-2003 08:38 AM
Any ASIO News? Rock_Artist 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-16-2002 10:09 PM
ASIO Beta News Avid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-12-2002 04:07 PM
