bounce - real time only?
is PT9 still limited to real time bounce "speed" or am I missing something?
Re: bounce - real time only?
Yes we're all missing something. One day we might get it but don't hold your breath. Sadly bounce is still real time.
That's disppointing at best. Been a PT user on and off since PT6 but some of my projects (backing tracks for live band medleys - up to 15 mins long) are just too long to sit through a bounce. Especially if something needs to get fixed (rebounced) and is discovered later. Been using Cubase for that.
Thanks for the quick reply. |
Yeah. It is still real-time. I heard it is due to RTAS, hence the name Real Time Audio Suite.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
I don't really mind the real-time bounce, but I do have a suggestion for future releases of Pro Tools:
Enable the user to save a given number (say, at least 6) of different mixes for bouncing, and have a "batch bouncing" option. That way, if I want to bounce a few different mixes, but they are a little longer, I could set my computer to "batch bounce" before I go to bed, and have all of those mixes done when I wake up. Perhaps we'd have to save a few different session files, and then have a separate utility to batch bounce the sessions? I don't know...just thinking out loud. If there's something like this already available, please - someone make me aware of it :)
Intel i7-4820K, 16GB RAM 128GB SSD (system) 1TB 5400 rpm hard-drive (audio drive) Pro Tools HD 2018 Universal Audio Apollo Twin w/ Black Lion Audio Premium Modification Focusrite 18i8 w/ Black Lion Audio Modification |
I think it's actually a limitation of Pro Tools HD since the processing is handled by DSP cards. Digi's thinking was that they didn't want LE to have a feature HD couldn't, so they never made offline bouncing available. BUT, with some major improvements and limitations lifted in PT9 by Avid, and with HD going native - hopefully this long-requested feature will be available soon.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (3) Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
I am another that doesn't mind the real time bounce that bad(how impatient are we anyway?). In any case, if you really hate it, you could bus everything to a stereo AUDIO track and keep that in record as you go. Once you reach the end, just consolidate the final stereo mix and export it.(check your punch points in case you need any cross-fades or region end adjustments).
Back about ten years -- a couple of fellow engineers and I did 'null tests' with bounce to disk versus real time mix to disk in MOTU's DP - and discovered the two mixes did NOT null. It was then we determined that we'd never use a bounce to disk over a real time run of a mix. I know the 'tech-ie engineer types' here on the forum will assure me there is no difference between bounce to disk and using busses to mix -- but there was a difference - at least in DP4. Some of you maybe were around at Gearslutz when I posted the proof files. It was 'eye opening' and made a lot of 'tech-ie' types scratch their heads. There are times when I'm glad I don't know what an 'ohm' is or what 'algorithm' means.. I just know what my ears tell me and that's what they 'pay me' for..
Rig 1-Mix/Mast: PTHD 11.3.1; MacPro 6core (6,1) 3.5 GHz Xeon E5; 10.10.3 (SSD Drives for audio); Apogee DUET, FireStudio2626 as Hware Inserts to PT for outboard Rig 2-Cutting&Remotes: PTHD 11.3.1; MacBook Pro (8,1) 2.8 GHz Dual i7; 10.9.2 (128GB int '6G' SSD drive); Profire LightBridge (FW800), 32ch Presonus Digimax FS |
I remember when I had Audiomedia III card with Pro Tools 4, that bounce was faster than real-time? Or was it when using Pro tools 4 with DAE PowerMix? Anyway, bounce faster than real-time has existed. So it's a question of AVID giving that feature back to Pro Tools users.
I understand that real-time BTD was created so you can use external effects when you mix down. If this is so, I'd like a bounce-fast option for those of us who mix in the box with no external processing. Jrestes927: I like the batch-bouncing option. I am often creating sound effects, edited music, and other bits of audio for theater, dance recitals, corporate events, etc. Often I am working on as many as 100 different audio segments that all need to be bounced individually. A batch bounce would let me walk away from the computer while it does its thing. Hey, it took only about 15 years of requests to get Digi to create the BTD keyboard shortcut. Maybe we'll get real-time bounce in another 15 years!
www.barnabas.com Barnabas MultiMedia |
Real-Time Bounce to Disk...REAL PAIN | Brian in Charlotte | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 201 | 07-26-2010 08:12 AM |
Non real time bounce | idris | Pro Tools TDM Systems (Mac) | 2 | 09-22-2006 02:33 PM |
Bounce only Real Time | Ronbfp | Tips & Tricks | 3 | 07-11-2006 11:59 PM |
Bounce NOT in real time? | Tony Moore | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-28-2005 04:28 AM |
Bounce Real-time | CueAV | Pro Tools TDM Systems (Mac) | 8 | 10-30-1999 12:44 AM |
