Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 07-09-2019, 09:06 AM
DonaldM's Avatar
DonaldM DonaldM is offline
Default What to keep on Session drive
My PT session drive is starting to get full. Of course I have everything backed up, but I've always hesitated to delete anything off the session drive...not sure why.
So, I was wondering, assuming everything backed up from session drive on a regular basis - which it is, how do you all keep your session organized? Do you automatically delete anything older than a certain point? Or some other method? I want to get the drive better organized.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Dell XPS 435T/9000 Win-10 Pro 24gig RAM
IntelCore i7 CPU 920@2.67GHz
Pro Tools 2018.12
Focusrite Scarlett 8i6
Old 07-09-2019, 01:09 PM
mjslakeridge's Avatar
mjslakeridge mjslakeridge is online now
Default Re: What to keep on Session drive
How large is your current session drive? You may consider buying a new drive of equal or greater size and just transfer current sessions to the new drive, and keeping everything on the old drive as a second backup.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ
Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit.
Old 07-09-2019, 01:39 PM
DonaldM's Avatar
My current session drive is 750gig, more than enough for anything current. Eventually I'll get a 1tb SSD, then I'll do as you suggested. For now, though, I want to clean off some stuff and organize things better. That's why I'm asking how you all keep things organized on the session drive.
Pro Tools 2018.12
Old 07-09-2019, 02:42 PM
AlexLakis AlexLakis is offline
Everything is organized by artist/project in the root directory of the session drive; nothing special. I back up every session that was modified when I get home to a 5TB backup drive and also to a NAS drive. Once the project is finished (and backed up to both drives), I remove it from the session drive (500gb SSD). I usually have between 300-400gb being used on the session drive for current projects during any given month. When a backup drive gets full, I buy a new (bigger) drive, copy all the old sessions over, and stow the old backup drive in a fireproof safe.
Hope this helps!
Old 07-09-2019, 02:44 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Not really answering your question but what i ended up doing was putting an fourth drive in. A nice cheap slow ass 4 TB 5k spinner that is both whole system back up and session drive copy. Then I can load old stuff onto DVDs/external drives from the session drives as actual back ups/archives, and if I don't have to pull something back onto the session drive from the internal copy in 90 days, i erase it/them from the internal back up.
I started out with 180 days, but 90 ended up being good for me.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 32 Gig Memory:Seagate 2 TB,1TB,4TB,500gb EVO OS Windows 7 Ultimate
PT 2019.6 Native through A&H Qu-32
Old 07-09-2019, 02:53 PM
EGS's Avatar
EGS EGS is offline
Originally Posted by DonaldM View Post
...I want to clean off some stuff and organize things better. That's why I'm asking how you all keep things organized on the session drive.
I backup to two identical externals (several pairs of spinners, in my case). Active projects, then, have 3 identical copies. When the project is 100% done, I delete the contents of the original session folder. Then, into this (now empty) session folder, I add a note telling me where (i.e. which 2 external drives) the backups are located. Just make sure you fully understand disk allocation, and make sure the backups have ALL the content. My internal session drive has LOTS of tiny folders, containing nothing more than a note telling me where to find the backups. Works for me!!!
Desktop: PT 2019 / Win 10 / GIGABYTE GA-X58A-UD3R / i7-980X hex @ 3.9GHz / 32GB / Focusrite LS56
Laptop: PT 10 / Win 7 / HP ProBook 4730s / i7-2630 / 8GB / U-PHORIA UMC1820
Info/Services link
Old 07-09-2019, 03:02 PM
DonaldM's Avatar
That's actually a decent idea, Gary. I like the simplicity of it. Thanks. In my case I'm only backing up my own stuff as I'm not mixing for others (usually). Thanks for this tip!
Pro Tools 2018.12
Old 07-09-2019, 03:03 PM
DonaldM's Avatar
Yeah, I'm thinking of going to 180days too. If I haven't done anything with a project for 6 months, I'm likely not going to for a long while.
Pro Tools 2018.12
Old 07-09-2019, 03:04 PM
DonaldM's Avatar
Thanks for the tips/suggestions. Helps a lot to think through the best way to do it.
Pro Tools 2018.12
Sample drive and PT session drive disappear stevedresser83 Windows 12 05-10-2011 03:23 PM
Contemplating SSD for Session drive BrendanClace 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-09-2010 02:19 PM
Fades corrupted when copying session from drive to drive? innerbooty Pro Tools TDM Systems (Mac) 3 03-10-2009 09:13 PM
Cant use Sata2 drive as session drive? Sofine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 12-16-2005 07:03 AM
Disc Allocation when transferring session from drive to drive... Roy Howell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 03-17-2003 03:37 PM
