Old 12-11-2016, 10:51 AM
Justin1524 Justin1524 is offline
Default Video: Pro Tools 12.6.1 HD unusable for 2 minutes after launch then fine
Have a look...
https://youtu.be/-p6GKTOWEJM
Using HD Native and Mid-2010 Mac Pro with 2 x 3.33 ghz cpus 12 physical cores, 24 virtual cores 64 GB Ram. Using macOS Sierra 10.12.1 and Pro Tools 12.6.1.HD with latest HD Core audio driver. Problem/Bug: upon launch, CPU jumps to 100% causing audio glitches for 2 minutes after launch then operates just fine. Reason? Solutions? Thanks!
Justin
Admin
www.elevenrackpresets.com
Studio: 2010 Mac Pro Tower Intel Xeon 12 core 3.33 GHz, 64 GB macOS Sierra PCIe SSD 256GB Boot | Pro Tools Ultimate 2018.4 | HD Native Card | Digi 192 Analog & 192 Digital Blue | Digi PRE, FR OctoPre MKII, Mackie Onyx 800R, Panasonic WZ-AD96M and DA7, Eleven Rack, Apogee Big Ben, Waves DLI, Impact Server, Horizon, Rode K2. Laptop: Dell Inspiron 5559, i7-6500U 2.6Ghz, 16 GB RAM, 15.6" 1920x1080 1TB SSD
Old 12-11-2016, 10:55 AM
Drew Mazurek's Avatar
Default Re: Video: Pro Tools 12.6.1 HD unusable for 2 minutes after launch then fine
Originally Posted by Justin1524 View Post
Have a look...
Check to see if it correlates the cache filling up. I see this issue and have logged it with Avid.
www.drewmazurek.com
Old 12-11-2016, 12:45 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
I have the same setup and the same issues. Curious to see what's happening, too!
-Ryan Young
•Pro Tools 12.6 (x2)
•OSX 10.11 & 10.12
•Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon (x2)
•16 GB 1333 MHz DDR3 (x2)
•HD Native PCIe (x2)
•HD Omni (x2)
•192 i/o
•96 i/o
•4 Seagate Barracuda 1.5TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
•Blackmagic Intensity Pro (HDMI)
I'm not sure I understand. How could the cache fill up on a session with no tracks whatsoever?
Justin
Admin
Old 12-11-2016, 12:54 PM
I didn't watch the video, you sold me on how boring it was.
No clue. Start a case and present the video to Avid.
www.drewmazurek.com
Old 12-12-2016, 12:09 PM
Haa! I just started a case via the Avid Support Center web form. Will report back if I learn anything. Let's see if my included ExpertPlus Support means anything. Not holding my breath.
Justin
Admin
Old 12-12-2016, 01:57 PM
TAMBOR TAMBOR is offline
Have a look...
It's obvious you've got way too much RAM, and too many cores.
I get high blood pressure from just watching the CPU meter, I've seen it on my system from time to time also with Wndows 7, not quite as bad. But I know the next thing to happen will be -9173.
Old 12-13-2016, 03:27 PM
24 hours since I opened a case and no response from Avid Support.
Justin
Admin
Old 12-13-2016, 05:18 PM
mrtomcat mrtomcat is offline
same issue here.
Mixing/Producing/Recording
PT Ultimate 2019.5
Wavelab Pro 9.5
UAD Satellite Octo Thunderbolt,
Apollo Twin Duo,
HDX Card running in Sonnet TB3 expansion box,
2x Avid I/O Analog 16/16,
4x Artist Mix, Avid Dock, PT Control,
Mac Mini 2018 32gig ram 1 TB SSD 6 Core running Mojave,
lots of outboard gear
Old 12-13-2016, 05:43 PM
jjnssn jjnssn is offline
Call them if it is urgent. I don't believe I have ever gotten a response on line in less than 24 hrs, more like 48 hrs
Have tried removing all plugins from the plugins folder just as a simple split the dictionary test? I figure you've already deleting of pref, caches, etc....
Also I am CST, I always get responses at or around 5:00pm.
____________________________________________
W10 Pro / X99 / E5-1650v3 / 64GB ECC / nVidia P1000 / ASUS TB3 AIC
PT HDX1 / OMNI / HD IO 16x16 / 11R / Kontakt Kontrol S49 / Artist Transport and Mix / UAD OCTO Satellite, Apollo Twin MKII &, x8P Thunderbolt
[Late 2013 10.14 MacBook Pro]
Pro Tools suddenly taking 10 minutes to launch-help? amiller Post - Surround - Video 7 12-30-2011 10:18 AM
Pro Tools 10 launch, the video crizdee Pro Tools 10 8 10-28-2011 12:40 PM
10 minutes to launch session parabola818 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 08-30-2010 11:39 AM
ProTools takes 5 minutes to Launch enafuit Pro Tools TDM Systems (Mac) 1 03-24-2010 02:53 PM
Help Pro Tools Won't Launch - Worked fine yesterday mnoxious 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-09-2007 09:17 PM
