Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 02-15-2015, 10:38 PM
Jumpman_Dreamin's Avatar
Jumpman_Dreamin Jumpman_Dreamin is offline
Default Hey guys im an an artist and slowly learning mixing but i want to know what would you
Hey guys im an an artist and slowly learning mixing but i want to know what would you add to the vocalor aux track to make it nore shiny or more energy grit just more
System Details: dell pc intel core i3 windows 7 running pro tools 11 with a soundbox 202 interface and a c-10 jammin pro mic and reflexion filter with samson mediaonebt3 monitors
Old 02-16-2015, 04:20 AM
Drew Mazurek's Avatar
Default Re: Hey guys im an an artist and slowly learning mixing but i want to know what would
Lots you could do. Aural Exciters, saturators, multi band comps, stuff like that.
BUT....
If you're just starting out, it's likely that you should concentrate on getting good at the basics. For me, getting a good vocal sound happens in this order:
1. singer is on point and having a good day (of course)
2. the room (yes, #2-you could have the best of everything but if the room is wrong, bad reflections etc, you're sunk)
3. mic
4. mic placement
5. A/D converter
6. pre amp
7. HPF and maybe some compression (yes, while recording-very lightly, once you know what you're doing)
During the mix:
EQ if needed to "fit" it into the track or attempt to correct something that didn't quite turn out during tracking.
Comp to manage dynamic range or add energy etc
DeEsser if needed
then the previously mentioned stuff above.....dlys, verbs, pitch related effects....
www.drewmazurek.com
Old 02-17-2015, 07:17 PM
Tom Graham's Avatar
Tom Graham Tom Graham is offline
BUT....
3. mic
4. mic placement
5. A/D converter
6. pre amp
During the mix:
DeEsser if needed
Agreed on all levels. There are also some cool - very simplified plug-ins too that will help you achieve a good 'radio ready' vocal sound. The Waves CLA Vocals comes to mind for $ 150 US Dollars. I'm sure there are several like that…
Tom Graham
Avid Audio Marketing
Pro Audio and Mixing
tom.graham@avid.com
Check out our Pro Mixing Webinars :
http://www.avid.com/US/resources/pro-mixing-webinars
Avid Pro Mixing Blog:
http://www.avidblogs.com/promixing/
Old 02-17-2015, 07:47 PM
Im really confused about a pre amp? What it does and do i really need it? A/d converter as well
Old 02-17-2015, 08:29 PM
Tom Graham's Avatar
You can buy an audio interface for your computer that has a built-in Mic Preamp and A/D converters. You need both for sure. The better the Mic, Mic Pre and Converters - the better your overall recording will be. Plug-ins can't fix everything. Good luck...
Tom Graham
tom.graham@avid.com
New to Artist Series, learning how to set it up and use it and now I have a problem. Freude Artist Series 0 07-05-2012 02:30 AM
A few mixing and recording questions for you guys mercbenz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-05-2008 01:10 PM
Any good recording mixing mastering learning DVD ? oust 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-15-2006 01:55 PM
POLL: How are you guys mixing? Maskeeper Post - Surround - Video 20 07-11-2005 09:21 PM
