Old 07-31-2011, 01:36 PM
Glitch Magnet Glitch Magnet is offline
Default Acronis Killed My Pro Tools
Everyone said install Acronis True Image, so I did. Now PT9 won't launch.
I have a dual boot of two copies of Win7 x64, one for my main everyday use, and one for my DAW. So, after reading the exhausting Acronis manual, I decided I should install it on my main OS and backup images of both my main OS partition and my DAW OS partition from there. Immediately afterward, my DAW OS booted fine, but when I tried to launch Pro Tools, it said ProTools.exe was corrupted. I rebooted and then chkdsk ran and found a bunch of errors. After that, I no longer get the error message, but PT still won't launch.
So I uninstalled PT, wiped all related files and folders, cleaned my registry, and reinstalled PT. Still, PT will not launch. Looks like I will have to wipe my DAW OS partition and start from scratch.
I have the Acronis backup image, but I'm doubtlful it will save me. After this experience, I'm scared to death to even try to recover it lest it should corrupt something on my main OS too.
It was my assumption that Acronis would only create a backup image of the drive. I never expected it to change the data on it, but obviously it did.
So, what is the right way to back up a dual boot system?
Old 07-31-2011, 02:23 PM
JMS40 JMS40 is offline
Default Re: Acronis Killed My Pro Tools
I've had 3 versions of TI, have imaged and restored dozens of drives, and it has never altered the data on the drives I've worked with.
Old 07-31-2011, 02:24 PM
Greg M Greg M is offline
Many, many of us have and use Acronis to back up and image our disks. This is the first I have heard of something like this.
While I know no details of your system, my guess is that you have a hard drive that is failing. Corrupting of files can be a sign of a failing drive. Drive activity during a back up or imaging is very high and can be a bit stressful to a failing drive.
I would suggest buying a couple of new WD Caviar Black drives, try to back up your sessions and important data and then replace the drive that is yielding corrupted files.
Hope this helps,
Greg
Intel i7 3930K, Gigabyte GA-X79-UP4 (rev 1.0), 32 GB Corsair Vengeance 1600 ram, EVGA Nvidea GT 720 TI video card, a Samsung 850 Pro (256 GB) OS drive, 2 Samsung 850 Pro's (512 GB) in externally mounted drive bays for session and sample storage, Win 10 Pro, PT Ultimate (Native)2019.6, HD Omni, HD I/O 16x16 .
Old 07-31-2011, 02:46 PM
lowthert lowthert is offline
Default
Ditto - this is not an Acronis issue (it has saved me countless times) - this is clearly a hardware issue...
ProTools 2018 / OS High Sierra / UA Apollo Twin Duo / Furman AC210AE / Samsung Evo 860 MVMe / Thunderbolt SSD Audio / i7 3.4Ghz /AMD Radeon 2G GDDR5 / 32G Crucial DDR3
Old 07-31-2011, 03:22 PM
TOM@METRO's Avatar
I am currently running on at least the 6th generation of Acronis restorations and/or clones with absolutely no related negative issues. I agree that your drive is suspect at this point.
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2019.6 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 07-31-2011, 05:16 PM
cwsand's Avatar
cwsand cwsand is offline
At least if you get a new drive you can (hopefully) restore your image from the backup.
Help Us Help You
Chris
__________________________________________________
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Gigabyte GA-Z170-HD3P / i7 6700K 4.1 GHz / 32GB Crucial DDR4
macOS High Sierra Version 10.13.6
Pro Tools HD 2019.6
Old 07-31-2011, 07:39 PM
Thanks everyone. The drive is a Caviar Black, just a few months old. I'll post my Sandra if it becomes necessary.
I'm real skittish with backup software since a bad experience with Norton Ghost a few years back. I attributed its failure then to its inability to handle a dual boot system. I beleive it crashed my computer as I was switching between OSes, then could not resolve the proper drive letters when I tried to restore. It kept restoring to the wrong partitions, and wouldn't let me choose. Anyway, that's old news.
But, I'm fearful and suspicious of a similar situtation here. Not that that explains why my PT install got corrupted. It doesn't.
Has anyone here specifically had experience with Acronis on a dual boot system?
Old 08-02-2011, 08:53 AM
SNAPPER SNAPPER is offline
windows7 has a built-in imaging system for backups, no reason to use a 3rd party app for this anymore.
Old 08-02-2011, 12:06 PM
EGS's Avatar
EGS EGS is offline
I prefer Acronis.
Desktop: PT 2019 / Win 10 / GIGABYTE GA-X58A-UD3R / i7-980X hex @ 3.9GHz / 32GB / Focusrite LS56
Laptop: PT 10 / Win 7 / HP ProBook 4730s / i7-2630 / 8GB / U-PHORIA UMC1820
Info/Services link
Old 08-02-2011, 08:53 PM
spenner spenner is offline
With HDDs and eSATA docks so cheap nowadays, use one partition for the system drive and use Acronis to keep a clone of it. The simplest way IMO. I have an eSata dock for this as well as for loading Win Vista and XP boot drives.
VST 2 RTAS Wrapper -KILLED PRO TOOLS - HELP PLEASE IntelDoc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 24 10-29-2014 12:01 AM
Pro Tools 9 killed my Garageband evankertman macOS 3 10-21-2011 07:23 PM
Pro Tools Update 9.0.5 Help! Midi Killed edisonmusic Pro Tools TDM Systems (Mac) 13 09-30-2011 03:03 PM
Pro Tools Killed Garageband Tyler Routson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-08-2007 11:40 PM
Pro Tools killed by AOL Conscious Structure Pro Tools TDM Systems (Mac) 14 04-03-2001 08:51 AM
