Old 11-28-2005, 05:22 AM
randykc randykc is offline
Default MIDI setup for protools 6.9
I've FINALLY upgraded from OS 9 to OS X protools and am completely lost on how to set up the midi with Protools 6.9. My set up is very basic, I have a basic keyboard controller (That I plan to eventually use to recieve midi for its sounds as well) that feeds into a proteus 2000 sound module for sounds and out to the protools midi end. This could be incorrect. For some reason the proteus 2000 will only recieve midi input from the controller but will not feed protools that midi data. When I attempt to map it within protools it will not allow the virtual patching from the proteus to protools either. Further more, i cannot get the proteus 2000 PATCH names to load up in protools.
PLEASE HELP!
Old 11-28-2005, 09:39 AM
DigiTechSupt's Avatar
Default Re: MIDI setup for protools 6.9
Check out Appendix C of the Getting Started Guide.
Avid Audio Tech Support
Support FAQ
Old 11-28-2005, 11:52 AM
Thanks!
is this any different for the digi 001? Sorry I should have specified that.
Also, while I have you. Does digi plan to do any more protools versions for the digi 001? I would love to run protools 7, but its not compatible
ProTools 10 and midi setup mattia77 MIDI 10 04-24-2013 07:57 AM
midi device setup with protools hd and mac robplato MIDI 1 07-29-2012 01:46 PM
m-pwered protools and midi setup godzflava71 Pro Tools M-Powered (Mac) 2 09-14-2005 10:28 AM
Can You Setup Midi Patchnames in Protools 4.1 razorrus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-18-2005 02:56 AM
NI Battery & ProTools midi setup SoundWorksUK MIDI 0 02-03-2002 09:20 AM
