Old 06-13-2002, 07:37 PM
Muzik77 Muzik77 is offline
Default Does "Consolidate" deteriorate sound?
Just curious if any tests have been conducted to determine what kind of deterioration the consolidate function causes. Any minsight is appreciated!
Old 06-13-2002, 08:14 PM
Digital Sound Lab Digital Sound Lab is offline
Default Re: Does "Consolidate" deteriorate sound?
[img]images/icons/confused.gif[/img]
Old 06-14-2002, 01:17 AM
Corey Shay Corey Shay is offline
It does not cause any deterioration whatsoever. And really, besides, why would it, and how?
Old 06-14-2002, 08:43 AM
DigiTechSupt's Avatar
The consolidate function is doing a bit for bit duplication of the existing audio. It's easy to test. Put some audio on a track and cut it up (or not ), duplicate this playlist so that you now have two playlists with the same thing on it. Consolidate one of them. Create a new track and put one of the two playlists on the new track with the other on the first track.
You'll need to put the same plugin on each track, be sure to put one on that has phase reversal button in it.
Hit the phase reversal button on one of the two tracks, the two tracks should cancel each other out.
Jon Connolly
Digidesign Product Specialist
Avid Audio Tech Support
Support FAQ
Old 06-14-2002, 05:39 PM
Interesting, John. I'll try it out.
Old 06-14-2002, 06:57 PM
Well, now I'm a believer! I did a test and consolidated random parts of a small passage over 30 times and when I flipped the phase it disappeared.
Consolidate vs Duplicate - "Stereo" vs. Dual Mono Behaviour rnd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-05-2013 01:03 AM
Best way to "consolidate" elastic audio tracks? rapsodie Pro Tools TDM Systems (Mac) 17 01-27-2012 10:18 AM
Anomalies introduced with "Consolidate" command (opt/shift/3) blawrie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-01-2011 11:18 AM
If I "Remove Unused Regions" after "Consolidate", track won't play? el biciclista Pro Tools TDM Systems (Mac) 10 04-02-2003 10:17 AM
Does "consolidate selection" affect quality?? Nine Spine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 20 03-12-2002 10:24 AM
