Old 05-22-2002, 09:04 PM
Muzik77 Muzik77 is offline
Default Do you know these tricks?
I know there's a keystroke for "create new Stereo track" and "create new midi track", but can't remember it and haven't found it documented anywhere. Anyone know this? It makes it easier when you don't need to enter a separate field.
Also, I was wondering if there is a trick using the grabber tool to specify that it automatically selects all regions everything to the right.
Thanks in advance!
Old 05-23-2002, 10:31 AM
PT2GO PT2GO is offline
Default Re: Do you know these tricks?
Create new track shift-command-n...
within the new track dialog, command-down arrow to change type of track...command-right arrow to change from mono to stereo
shift-option-return to select everything to the right. shift-return to select everything to the left.
If you use the selector, you can double click on the region you want to start with, and not have to get the grabber.
Jerry
Nashville, TN
Old 05-23-2002, 05:10 PM
Jerry,
Thank you so much! Exactly the info I needed.
old dog, new tricks :) rob wots Eleven Rack 2 02-15-2014 03:25 PM
Hi Hat Tricks RussUK Virtual Instruments 1 09-04-2009 12:35 PM
OSX Tricks Spiritwalkerpro General Discussion 3 12-10-2003 02:48 PM
low end tricks troswalt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 09-29-2003 02:27 PM
Mix Tricks pookadilly Pro Tools TDM Systems (Mac) 10 01-08-2003 12:05 AM
