Old 05-19-2002, 09:13 AM
Muzik77 Muzik77 is offline
Default Automation Shortcuts
First of all, I want to share a great shortcut I recently learned:
To quickly automate a plug-in, hold down CTRL OPTION COMMAND and click on the parameter you wish to automate. Select Enable.
I now have a question. Is there an easy way to make global changes to volume aqutomation. Specifically, here's a scenero: I have a track with lots of volume automation. I would like to lower the overall volume of the entire track. Is there a shortcut to do this in the Mix window,ie,without going to the Edit screen and scaling the automation.
One other quirky question: When I solo a track, an un-solo'd track will also play. Any ideas?
Old 05-19-2002, 09:18 AM
SAMP SAMP is offline
Default Re: Automation Shortcuts
This same question popped up recently. Here's the poetic and oh-so-cool reply from lcouri :
Select the 'clip' tool (in between the magnifying glass and the standard cursor button) and go to0 the end of the waveform which has been automated. follow the automation line past the end of the waveform and apply the cursor (with the clip setting) to the line. Once the cursor 'changes' over the line, click the mouse and you should notice the entire line become dotted .... now you can raise or lower the overall level. Save first then fool around with this for practice ....
Lately, I've been saving my favorite posts on a sticky on my desktop. Makes it easy to locate those gems that come about frequently 'round here... [img]images/icons/grin.gif[/img]
http://www.rullian.net
Old 05-19-2002, 06:11 PM
I'm looking for a shortcut to do this in the mix window.
Old 05-19-2002, 06:19 PM
Slim Shady Slim Shady is offline
<font size="2" face="Verdana, Arial">Use the trim plug-in
<font size="2" face="Verdana, Arial">Do you have the other track in solo-safe mode? this will cause the track to play even if you haven't solo'd that particular track.
Old 05-19-2002, 09:27 PM
thanks slim. does the trim function deteriorate the sound?
Old 05-19-2002, 10:34 PM
Not that i've noticed, it's just a gain adjustment.
You can also accomplish the same thing if you're using any EQs or any other plugs that have an input or output level adjustment (like the waves ren. EQ). Just bring down the level of one of those global paramaters, and you've got a 'master' gain control for that track.
Old 05-22-2002, 10:54 PM
Anyone know off a shortcutt for this?
Old 05-22-2002, 11:21 PM
CCash CCash is offline
The shortcut has been omitted from LE... one of many automation shortcuts. It is called Trim Automation and it's great. As it is, you have to mouse around with little fingers and the trim tool.
Slim- I thought the Trim plug was TDM only. What version of LE are you using?
Keyboard shortcuts for automation? calle.vs Post - Surround - Video 2 04-15-2009 09:17 PM
Pan Automation Shortcuts?! spike.mk Tips & Tricks 8 12-22-2008 06:18 PM
Pan Automation Shortcuts?! spike.mk Pro Tools TDM Systems (Mac) 3 12-02-2008 12:51 PM
Move ALL automation on ALL tracks - any shortcuts? Trailerman Tips & Tricks 4 06-25-2005 04:25 AM
Automation mode shortcuts poppy Pro Tools TDM Systems (Mac) 1 07-20-2003 01:41 PM
