Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 10-04-2023, 08:23 AM
Geoff_Mitchell Geoff_Mitchell is offline
Default Weird Dverb automation bug
Has anyone else encountered this behaviour?
A track was writing automation without being touched. (auto mode going red and capture coming on)
Recieved a session from sound designer with some D-verb integrated into session. The track with D-verb was dropping into a automation writing (red) when in touch or latch without being touched! Abit worrisome. (I tracked it down by cycling through the automation parameters until I came to the automation writing in the size parameter.) It seems to be putting itself into writing automation when there is a change in the size parameter ie. jump from a spot with "small" enabled to a spot with "large" enabled and it will go into automation writing without any touch. Replicated it on a second system.
I know, I know, Deverb? - but the designer was attached to their setup and we were keeping it as a reference when it starting printing new values ...
PS. not able to reproduce the bug in a clean session. So .. some kind of one-off.
Old 10-04-2023, 11:15 AM
its2loud its2loud is offline
Default Re: Weird Dverb automation bug
💯 this has been a bug with Dverb for centuries. I have tried to get it fixed repeatedly with no results.
Old 10-05-2023, 04:01 AM
mattrixx mattrixx is offline
I can't believe this still hasn't been addressed.
Not sure it's entirely auto based, as I would have a small room mono thing going on with a dialog track and recall the session the next day.... next thing.. Large Room... and obviously in the audio..
It's a shame, because Dverb in mono on Dial, was actually really easy to recreate room ambience.
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
weird 9.0.5 automation bug DHG MUSIC Pro Tools 9 6 08-23-2011 07:35 AM
Automation Help - Weird Behavior Daniel Sasso Pro Tools TDM Systems (Mac) 4 03-26-2010 10:32 AM
Weird Automation Behavior Daniel Sasso Post - Surround - Video 2 03-26-2010 07:55 AM
PC 001 to Mac TDM weird automation happening Quint Randle Pro Tools TDM Systems (Mac) 1 04-20-2002 08:02 PM
001 to TDM weird automation problem Quint Randle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-20-2002 01:51 PM
