Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 05-16-2023, 06:56 AM
Goombot Goombot is offline
Default Synch pop Atmos print and Re renders
What is the best way to get a proper -20db synch pop through the renderer onto the main ADM and on all channels of the Re renders? A tone track routed to an object?
Old 05-16-2023, 07:10 AM
its2loud its2loud is offline
Default Re: Synch pop Atmos print and Re renders
Tone track(s) sent to each Bed and on each Object if that’s what you want.
You don’t need to worry about the Rerenders since those are generated from the Beds and Objects.
Watch your monitors and ears if you’re listening to all of those 2pops at once. But since all these pops will be cumulative, they will be louder than -20dB on the Rerenders.
May I ask, why do you need this? The ADM file and Atmos files all have TC metadata
Before Dolby Atmos there was Ford Atmos gives Pro Tools 0 12-31-2022 02:12 PM
Pro Tools Quick Tips: Offline Bounce of Dolby Atmos® Re-renders Avid Avid Pro Mixing General Discussion 0 06-30-2022 01:13 PM
Routing Live Re-Renders from Dolby Atmos Production Suite into Protools HDX paulo m Post - Surround - Video 15 01-01-2022 06:56 AM
Audio in synch with quicktime, out of synch in FCP WannabeSQ Post - Surround - Video 6 09-20-2006 06:47 AM
OMF Export from LE 6.1.1 renders all fades Noyzey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-28-2003 03:24 AM
