Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 02-23-2020, 02:29 PM
Southsidemusic's Avatar
Default Re: Please recommend a cheap controller.
Originally Posted by albee1952 View Post
Most devices handle stereo panning by using the SHIFT button. From your replies to other suggestions, the Artist Mix is probably your best choice. Qcon makes some HUI units that are worth a look before you pull the trigger on anything
I would have said that too hadn’t the OP said no eucon device.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 02-23-2020, 05:17 PM
bcwiz's Avatar
bcwiz bcwiz is offline
Originally Posted by the19thbear View Post
The command8 is just so darn big though. And I think it only supports hui. Then I might as well get a small Behringer.
But thanks for the suggestion:)
Command 8 is a Pro Tools integrated controller like C|24 or 003 etc. but can be used with other software in HUI mode.
However if it's too big...
Brian Campbell
"Air mixes better than any console" Bill Porter
"Humility is mighty important in this business of listening" Bob Olhsson
Old 02-23-2020, 11:34 PM
the19thbear the19thbear is offline
Yeah, it sadly is too big (that’s what she said... couldn’t resist..)
Old 02-24-2020, 01:41 AM
Hopefully she didn’t say ”sadly it’s too big”
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 02-24-2020, 02:27 AM
I guess that can be a problem as well... oh well. Back on track
I think I will write icon and ask them more about the unit and hui or at least read through their manual.
Will report back.
Side note: the reason I want this is because I have been looking into recording drums in a new way. Been looking a lot at tchad Blake and the way he does things.
Super inspiring! Will have to pay to watch some “mix with the masters” videos.
Highly recommend looking into what he an Sylvia Massey are doing.
Experimented a bit myself yesterday and it was just one of those times where you find new ways of doing old things, and it’s like starting all over in audio again (in the good way. Feeling excitement again).
  #16
Old 02-25-2020, 12:00 PM
EddieJones's Avatar
I should be pushing S1....but if its all you can afford you would be crazy not to get an Artist Mix (Under $300 on ebay) Not only do you have All the EUCON features and the tie in to the Control App, EUCON is still updated unlike HUI. I bet you would start to use more of the features too once you got used to it.
  #17
Old 02-25-2020, 10:30 PM
Thanks. Might just end up with that but we will see.
The old silver models and the newer black versions are the same, right?
  #18
Old 02-26-2020, 07:16 AM
EddieJones's Avatar
Yes the black and silver are the same inside.
  #19
Old 02-26-2020, 07:37 AM
Default Please recommend a cheap controller.
#NoRacism
Weird joke....
But thanks. Will look into the silver models then.
  #20
Old 02-26-2020, 07:40 AM
EddieJones's Avatar
The silver ones are out of Support meaning if they go wrong you wont be able to send in to Avid for repair....but the cost of repair would be more than the current 2nd hand price anyway.
Recommend cheap and simple midi controller? Silence MIDI 2 03-27-2011 08:05 AM
Recommend a cheap audio A/D converter with s/pdif out owen247 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-09-2011 09:24 AM
i lookong for a cheap usb controller markolone General Discussion 2 08-27-2010 03:22 AM
Can Someone recommend a cheap but reliable external drive? asiabackpacker Storage Subsystems 1 05-20-2008 04:05 PM
Any pci ata 100 controller to recommend?? minuaño 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-17-2001 12:55 AM
