Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
  #21
Old 06-20-2020, 02:07 PM
Third Eye Studios Third Eye Studios is offline
Default Re: XMon Breakout Cable-DIY
Originally Posted by EddieJones View Post
And the light on the xmon doesn't flicker?
Sent from my HMA-L29 using Tapatalk
Hi Eddie, the Midi RX light on the Xmon does not flicker when hooked up to the Uno.
  #22
Old 06-21-2020, 04:33 PM
EddieJones's Avatar
I would suspect the cable then
  #23
Old 06-21-2020, 06:26 PM
Thanks Eddie. Pretty sure you are correct. Last night, after reviewing the breakout cable pdf, I believe I have pin 4 and pin 5 swapped. I used the midi cable diagram on the pdf, which shows a female connector. But I built the cable with male connectors, so pin 4 pin 5 swap. My bad all along. Doh!! I'll be able to test this tomorrow at the studio, but I'm sure it's going to work now. Thanks for your's and MrDibS help!
  #24
Old 06-23-2020, 10:29 AM
Well, I still don't have it working. Since I'm using male midi connectors (instead of female in the drawing), I thought swapping pin + and - would work for me. It didn't. Not sure what to check next...
  #25
Old 06-26-2020, 09:14 PM
MrDibS MrDibS is offline
I can't be sure what isn't right but I can share pictures of my dB25 connections. The grey wires are the midi cables. They are male connectors as well.
Mac Pro 2013 12 Core Trashcan, 64 gigs, OSX 10.14.6
PT HD Ultimate 2021.12 HDX with Focusrite Red 8pre, Rednet 2, R1, Dock + S3.
  #26
Old 12-15-2020, 03:35 AM
Suad Cokljat's Avatar
Suad Cokljat Suad Cokljat is offline
Hi. Did you get it to work? I'm waiting for my XMON to arrive (bought on Ebay) and I have same setup as yours (Pro Tools HD 10 on Windows 7 PC). Yes, you're not the last one to use PT10HD ;-)
Best regards,
S
  #27
Old 04-29-2021, 02:00 AM
I just made XMON breakout MIDI cable and all works great from the first try. I soldered connectors rather than use bulky terminal breakout board. It's easy to make and requires minimal soldering skills.
If anyone needs help with making the cable, ask here and I'll try to help.
Cheers!
Suad
  #28
Old 03-26-2023, 12:14 PM
Sugarnutz Sugarnutz is offline
Cheers!
Suad
What schematic did you use as there’s been some confusion as to what’s correct for the MIDI wiring. Thanks in advance!
Gigabyte z390 Designare
I9 990K 4.7 GHz
64 Gb of DDR4 3200
Gigabyte RX580 8 Gb
Win 10 Pro
15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM
512 Gb Flash Drive - OS X 10.14.6
  #29
Old 04-23-2023, 03:43 AM
Will Russell's Avatar
Will Russell Will Russell is offline
Greetings!
Bumping this thread. It seems the links in this thread to the cable wiring have all gone dead. Anybody still have this information who would be willing to pass it along!
Thanks!
Will Russell
Electric Wilburland Studio
https://linktr.ee/wilburland
M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock
M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS
  #30
Old 04-24-2023, 10:32 AM
EddieJones's Avatar
Link to drawing
XMON Eucon Software and wiring Control-Breakout Cable moacito System 5 3 05-02-2013 08:26 PM
MOBOX 3 PRO Breakout Cable SimonBarSinister 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 12-22-2010 08:23 PM
XMON breakout cables tonmeistermat Post - Surround - Video 0 03-31-2010 09:10 AM
Breakout Cable gerax 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-06-2001 06:52 AM
