Go Back   Avid Pro Audio Community > Pro Mixing > System 5
Old 07-31-2016, 12:14 PM
shauli shauli is offline
Default MCpro, open hardware instructions
I need to open the cover of the MCpro so I can check the input voltage and fix power supply issues.
Does anyone have instructions/pictures/video on how to open the case and see the motherboard?
The MCpro is in a 7' frame so instruction is very welcome.
Old 08-01-2016, 02:02 AM
dbf's Avatar
dbf dbf is offline
Default Re: MCpro, open hardware instructions
Hi Shauli
Return your MCPro upside down and put it on a soft cushion or anything which could protect switches, buttons, fades, screen and joystick. Then unscrew all the screws around the back plate. The remove the back plate and you will have access to all the components inside very easily.
DBF
Quality is a fight of the future
www.labomaticstudios.com
Beta testers wanted for MCPro and S5MC EddieJones System 5 7 07-31-2016 10:56 PM
Mixed MCPro and Artist Mix Environment aashton Artist Series 0 03-23-2014 06:55 PM
Hardware menu won't open chalz2502 macOS 2 12-21-2013 07:02 PM
Open PT 9 using ONLY hardware?? blbar10 Pro Tools 9 6 07-19-2011 06:59 PM
Benefits of Protools 9 for MCPro ? Studiomeijer System 5 0 11-09-2010 07:56 AM
