Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 04-30-2015, 09:21 AM
priorytools priorytools is offline
Default Automation Question .
Hi All.
So what I need is to be riding a fader & writing the level but be able to "print" or "save" the moves as I go . So for example, if a verse has 4 vocal lines; I'm rolling, I've made moves for lines 1+2 I like . . I want to hit a button/key commend that turns the red auto info just written from red to black without having to stop the transport. .
Any ideas ?
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Old 04-30-2015, 10:17 AM
Drew Mazurek's Avatar
Default Re: Automation Question .
Can't do it AFAIK.
The line goes from Red to Black once you hit stop. It's called a "mix pass". Which is a good thing, as this is what's "undoable" and in the Undo buffer.
What specifically are you looking to do?
If you get moves on lines 1and 2 you like, you can look into Join or Autojoin to "pick up" from where you left off to get rid of things you don't like etc.
www.drewmazurek.com
Old 04-30-2015, 10:34 AM
Hi Drew.
I guess it's to have a more detailed undo. .
I'm doing this in trim over previous moves.
It's the doing it on the fly that I'm after. .
If automation is written to a point that I like, I have to stop in order to give that piece of work it's own undo stage . . So if I do lines 1,2 & 3 but 3 isn't good, I've lost the move that was there for 3 before .
Am I explaining this . ?
Old 04-30-2015, 10:47 AM
Originally Posted by priorytools View Post
Hi Drew.
makes sense.
You should work with a dedicated Trim Playlist and have Coalesce set to manual. Then Trim passes will be on their own playlist. That way if move 1 and 2 are good and 3 and 4 aren't you can delete them on that, then coalesce.
make sense?
www.drewmazurek.com
Old 04-30-2015, 11:25 AM
Hhmm… sounds good.
Trim playlist ? I'm not aware of this.
I'm riding an aux not a vca.
Is that a vca feature ?
Old 04-30-2015, 11:59 AM
Hhmm… sounds good.
No, it's not VCA related.
Go to prefs and choose Manual for coalesce Trim auto.
Then in the View/Automation menu, make sure Trim Playlist is checked.
This way, you're writing to the Main auto playlist when in all modes other than Trim. When in Trim mode, your data is stored on a dedicated Trim playlist. This data will stay put until you manually coalesce it.
Makes sense?
www.drewmazurek.com
Old 05-01-2015, 05:15 AM
Hi Drew . .
Sorry for my delay in replying .
Wow, I've never been aware of that . Just ain't thunk it
Am working on another project today, but I'll try your suggestion on Tuesday when I'm back on that live BluRay project.
Cheers
Old 05-03-2015, 03:31 AM
nigelpry's Avatar
nigelpry nigelpry is offline
Makes sense?
I hadn't picked up on that either Drew .... thanks for the lesson ;-)
I'll be giving that a go too this week.
Mac Pro 2009 with 2010 firmware, 12-Core 3.46ghz, 64gb RAM & working Thunderbolt, OS 10.14.6 and Windows 10
iMac 2012 27", 3.4ghz i7, 32gb RAM OS 10.14.6
Digi 003 Console for control surface only, Focusrite OctopreLE and MOTU Traveler for extra analog-ADAT conversion, UAD Apollo Quad Silver with Thunderbolt card, Apollo x4 and pci-e Octo, Adam A77X monitors.
Pro Tools 2022.4, Media Composer 8.9, Sibelius 8.7, Cubase Pro 11, Wavelab Pro 11, Logic Pro X 10.5.1, Mainstage 3.
Various apps, soft synths, FX plugins.
Plenty of hardware synths, rack gear, microphones etc.
And then there's the studio ;-)
Old 05-05-2015, 02:50 PM
Hi Drew.
Yeah, that works. But one still has to stop the transport.
Would be slick to manually coalesce on the fly.
Avid… any chance of implementing ?
Old 05-05-2015, 03:23 PM
mesaone mesaone is offline
What about preview automation and write-to-selected?
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
Mix Automation Question samskimusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-09-2010 03:37 PM
General Venue Automation Question - (Maybe dumb question) TwoPort VENUE Live Sound Systems 5 12-21-2007 02:41 PM
A question on automation Peter Groom Post - Surround - Video 5 03-03-2007 06:20 PM
Automation question Dopamine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-25-2003 08:09 PM
automation question c_hebb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-24-2002 09:47 AM
