Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
  #21
Old 08-16-2014, 03:01 AM
Emcha_audio's Avatar
Default Re: Avid, please make this.
Originally Posted by Southsidemusic View Post
Worx here aswell iPad 4 Retina Voted but we are only 2!?!? votes ..
Even if Avid won't even consider this we can atleast let them know what we would like to have in the future by posting here on the forum and voting on ideascale.
Thanks Manny. Talk soon
Chris
Saw your vote and yeah.. we're the only two even though there's more that said they would like it.. hmm
oh well.. might just by a s3, a knob module and a control and then patch them all up together with ducktape
Weeeeeeeeeeeeeeeeeeeeeeee
Manny.
Wave-T.com
  #22
Old 08-16-2014, 04:19 PM
YYR123's Avatar
YYR123 YYR123 is offline
Man I had to log into a safari window to click the link....
I think tapatalk is in need of an update
Daniel
  #23
Old 08-17-2014, 02:34 PM
Kristo Kotkas Kristo Kotkas is offline
If you take a look at the bottom of the S3 surface you will see you won't need tape to attach sidecars, someone has already thought about it... what else they might have thought about? I wish they have thought about a sidecar with dedicated EQ section and a bunch of Function Keys (with LCD scribble strips!). And a surround panner. And a set of encoders that always snap to the plugin that is open on screen.
  #24
Old 08-17-2014, 02:58 PM
LOL that was me being sarcastic.
Can you take a pic of that, cause I haven't noticed it.
Manny.
Wave-T.com
  #25
Old 08-17-2014, 08:06 PM
YYR123's Avatar
I like those ideas, kinda of like a mini
d-command with eucon
Daniel
  #26
Old 08-21-2014, 04:47 AM
Drew Mazurek's Avatar
Originally Posted by 8dB.co.uk View Post
How about one with 8 faders either side of the touchscreen, so you don't have to go off axis?
Oh hang on, that would just be an Artist Control and 2x Artist Mix....
Nope. I used Artist Series pics for convenience but the "real" unit should be S6 components all around.
And 8 faders per side is fine by me as an option.
www.drewmazurek.com
  #27
Old 08-21-2014, 11:14 PM
8dB.co.uk 8dB.co.uk is offline
Absolutely makes sense to put the assignable section in the middle.
Pro Tools Utimate 2018.7, on -
i7 5820k 6 x 4GHz (12 threads), 16GB DDR4, Win 10 Pro, BM Mini Monitor PCIe, GTX 660Ti 2GB;
Dell Laptop, i7 4x3.6GHz (8 threads ), 16GB DDR4, Win 10 Pro, GTX1060MaxQ 6GB;
"Plan B" - i7 6700k, 4 x 3.4GHz, 16GB DDR4, Sierra, AJA Kona LHi, GTX 1050Ti 4GB.
RME FireFace802 + ARC, RME Babyface
Avid D-Command, Artist Control, V-Control, Korg MicroKontrol
7.1.2 Presonus Monitors
  #28
Old 08-22-2014, 12:02 AM
Truly depends on how you work. For me it doesn't, for you it does, so the best option would be to have a modular system where both configuration would be possible. As I wrote before, if the S4 we are proposing stays the same size as it's components, you will have plenty of arm length to reach the last encoder of the 8th column (last column) 4rth encoder row (top row) which is the furthest away without even having to bend/tilt out of position even if you're working with an inline fader configuration.
By the way the width of the S3 right now is 28 inch, that includes the wings (where the retractable legs are) which in this design idea one of the second key section is no longer there (that could be placed under the touch screen with a touch pad) so that might be 4 to 6 inch less, the width of the knob module of the s6 is 12 inch. that makes a total of 36 inch (34 inch if you take out the second key section from my revision of drew's idea), if you're sitting in the middle that leaves less than 16-18 inch of reach to reach the furthest knob in the section. And if you're like the average man in the united state and have a shoulder width of 18 1/4 inches (for a 5'10" person) and 32 inch of arm length (9 1/8 inch from spine + 32 inch (arm length) = 41 1/8 inch reach from the center of the console), for the average person that would mean you would be able to reach the furthest knob without having to go off axis. Of course that diminishes a bit if your like me and have a bit of a belly
Manny.
Wave-T.com
  #29
Old 08-24-2014, 12:28 AM
JCBigler's Avatar
JCBigler JCBigler is offline
It needs a master fader! Why can't anyone make a control surface with a fracking master fader?
And LED scribble strips.
Justice C. Bigler
www.justicebigler.com
Lenovo P50: quad-core i7-6820hq, 64GB, 2TB SSD, Win 10 Pro / Protools Ultimate 2023.6 / HD|Native-TB
2018 MacBook Pro: six-core i9, 32GB, 1TB, Monterey / Protools Studio 2023.6, / DVS / DAR, L-ISA Studio
Home/mobile: Focusrite Red 8Pre+HD32R / Clarett 4Pre
Road/hotel: Roland OctaCaputre / Apogee One
  #30
Old 08-24-2014, 12:31 AM
Nah. A ProTools control surface needs a master fader like a roast chicken needs a submarine.
I wish AVID would just give up on HD Native and make this box -- propower General Discussion 9 03-26-2014 01:03 PM
Will Avid make PT 10 work with OS 10.9? Touchwood Studios Pro Tools 10 18 12-05-2013 11:41 PM
Will Avid Ever Make Midi A Top Priority?! shamanrock Windows 20 01-05-2013 01:21 AM
AVID needs to make a PT10 to PT9 utility app SOUNDDECISION Pro Tools 10 91 10-14-2012 09:58 AM
