Old 12-14-2013, 10:15 AM
Farmer Dave Farmer Dave is offline
Default Scroll wheel inverted in PT11 - clip gain?
10.8.4
11.0.3.14
2.66 Ghz Quad-Core Intel Xeon
16GB RAM - 1066 MHz DDR3
I've looked all over and can't find a setting for this. in PT10.3.6, my clip gain scroll wheel changes values in one direction, and in PT11, the values go the other.
I am using a Kensington Trackball, but that doesn't allow application specific settings anymore and I can't find anywhere that the scrolling would be inverted for one app but not the other...
Old 08-16-2016, 09:31 AM
tbsound tbsound is offline
Default Re: Scroll wheel inverted in PT11 - clip gain?
Did you find the solution to this?
I am on PT 12.5 with the kensington track ball and the same thing has happened. All scrolling is the right direction except clip gain scrolling. If I change the settings everything else becomes inverted.
Old 08-16-2016, 11:43 AM
Honestly I can't remember since I never boot PT10 anymore so can't remember how it was performing.
I'm still using the Kensington with PT 12.5.2, on Mac 10.10.5.
If turn the wheel to the right, clip gain goes down in value, and vice versa for turning to the left. Which I THINK, was the way I used to use it in PT10.
I do have Trackball Works from Kensington installed, and the "Scroll Down" selection is set to the right hand "button" selection.
In the system prefs "Mouse" Scroll Direction Natural - is unchecked.
I hope this helps! I can't recall if there was anything else!
PT11 and clip gain question Connor Pro Tools 11 3 11-04-2013 02:14 PM
Scroll Wheel CamM macOS 2 08-17-2012 02:12 AM
Controlling clip gain with the scrub wheel? IO Composer Artist Series 4 03-14-2012 02:40 PM
Scroll Wheel? s0nguy ICON & C|24 8 05-12-2005 08:43 PM
