Old 03-03-2013, 08:07 AM
sharp11 sharp11 is offline
Default Omni causing "Creating DAE object" hang on boot-up
After the arduous task of downloading multiple gigs worth of software from Avid's site - after updating Java and waiting all day for PT 10.3 native to download, it wouldn't boot - it would hang repeatedly at the "creating DAE objects" portion. I found a work-around c/o the knowledge base - you hold down the N key during bootup and select a different "interface", in this case, the internal Mac inputs - save a session, then reopen and choose the Omni interface. It now works, but what a pain - this is clearly a bug that needs to be addressed.
I hate this idea of ilok updates and multi gig downloads - I have to spend an entire weekend installing software (which in this case is buggy) where a proper installer disk would've had me up and running in one evening.
Thanks for listening.
Protools native HD on a 12 core Mac, OS 10.8, Omni interface.
Old 03-03-2013, 08:46 AM
KMcK KMcK is offline
Default Re: Omni causing "Creating DAE object" hang on boot-up
I have 3 rigs with the Omni interface and HD Native card running PTHD 10.3.3 on 10.8.2 and don't have this issue.
Please post more detailed system specs (actual PT and OS versions, full CPU specs as well as any other 3rd party hardware connected etc) and we'll see if we can get you up and running.
http://www.imdb.com/name/nm2384808/
Old 03-03-2013, 11:14 AM
Ale Ale is offline
In mine case I just had to reset omni from the front panel and all was well
2 PT HD Ultimate 2023.12 6/12-Core Westmere/ 48/96 GB / OS 10.14.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1)
1x PT 2023.12 Rosetta / MacMini M1 / 16 GB / monterey / SSL2+
Old 03-04-2013, 07:57 AM
Thanks, I probably wasn't clear in my post, but I'got it working thanks to the workaround I found in the knowledge base.
I haven't run multiple tracks yet as I'm still downloading and configuring the Omni etc.
So far the air plug-ins are great, I may not even bother to transfer my soundtoys suite over from TDM to native.
Boot Screen "Not Recognized Video Hardware Connected", "video engine failed to init bcrichguitar macOS 3 04-01-2012 09:10 AM
Protools LE 8 hang while "setting up peripherals" and while "loading tracks" xfarre 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-22-2011 07:37 AM
SYSTEM HANG on "Installing Digidesign hardware drivers" jcaseyonbass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 10-02-2009 04:15 PM
SYSTEM HANG on "Installing Digidesign hardware drivers" Jim Casey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-02-2009 01:14 PM
comm 8 makes PT 8 to hang at "initializing machine control" music project ProControl, Control|24, Command|8 0 12-24-2008 02:02 AM
