Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 01-02-2013, 10:41 AM
TCM's Avatar
TCM TCM is offline
Default Dae errors -9171 after installing 10.3.3
Just want to report that after installing 10.3.3 I have a lot of above errors - unlike in 10.0, which I was running before -. I also get a BSODs after that, though not immediately. Very annoying.
I wonder if there is a driver problem, or what is happening, as 10.3.3 is otherwise running very smoothly.
Time to run a hardware check.
I'll keep you posted.
In case anybody has a suggestion, please post. Thanks.
Thomas
002R BLA mod and Mbox mini 2, PT 11.3.2,
HD Native, HD IO 16x8x8, PT 2018.7, Win 10 Pro 64, Asrock X99 Extreme6/3.1, i7-6850K, 32 GB Ram, SSD system drive, ssd audio drive
Old 01-02-2013, 08:11 PM
Default Re: Dae errors -9171 after installing 10.3.3
Did you do an update or fresh install??? I have had no issues with it. I went from a clean install though and did not update the previous install.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 01-03-2013, 02:11 AM
TCM's Avatar
TCM TCM is offline
I uninstalled the previous version first.
Old 02-06-2013, 10:18 AM
TCM's Avatar
TCM TCM is offline
Bluescreenview revealed that the MAudioAxiom.sys (driver for my Axiom 49) is a cause for this.
-9171 and -9172 errors with Pro Tools HD 10.3 on HDX Boe Larsen Pro Tools HDX & HD Native Systems (Mac) 519 03-08-2017 10:11 PM
64 Sample Buffer and -9171 Errors sws2h Pro Tools 10 2 07-19-2013 07:21 PM
Pro Tools 10.3 9171 and 9172 Errors Tops3b Pro Tools HDX & HD Native Systems (Mac) 20 07-14-2013 03:11 PM
UAD triggering 9171, 9172 errors? xq3js macOS 7 03-22-2013 11:47 PM
10.3.3 Major Fail....9171, 9172 and 9129 Errors Tops3b Pro Tools HDX & HD Native Systems (Mac) 3 12-21-2012 07:21 PM
