Old 12-24-2010, 03:58 PM
shauli shauli is offline
Default HD9 crush on start up connectiong to DSI
New install PT9 HD1 on Windows 7 64 bit. When PT start is will crush when getting to connection to DSI. Digi test also will not start.
Tried re-installing, did not help.
Anything I can do?
Hardware is 2x Lynx Aurora 16 with HD card.
Old 12-24-2010, 11:53 PM
GtrDude GtrDude is offline
Default Re: HD9 crush on start up connectiong to DSI
I'm starting to wonder if PT9 is a complete disaster.
I don't think I've seen so many complaints about previous versions.
Well,,,,,,now that I think of it, it wasn't pretty when 8.0 came out.
GD
Old 12-26-2010, 05:46 AM
bump. Any one?
Old 12-26-2010, 05:55 AM
Dism Dism is offline
Help us Help You - READ THIS Before Posting!
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 12-26-2010, 07:18 AM
digidesigner digidesigner is offline
Coming from Mac G5 PT8 to Win7/64 I must say my Pro Tools9 experience has been great, some hardware problems getting a new system to work, but after that, the program has served me well.
I would do some optimizations suggested in this thread:
http://duc.avid.com/showpost.php?p=1712789&postcount=5
and I would go thru what Avid suggests you should do:
http://avid.custkb.com/avid/app/self...p?DocId=349411
And if that does not help, I would start to look for hardware issues, I had a bad motherboard and then bad memory, one can have sometimes a really bad luck I guess.
Old 12-26-2010, 07:27 AM
This is new install, computer was optimize for Pro tools.
Here is the Sandra report.
SiSoftware Sandra
Computer
Model : Supermicro X7DWA
Processor
Model : 2x Intel(R) Xeon(R) CPU E5410 @ 2.33GHz
Speed : 2.33GHz
Cores per Processor : 4 Unit(s)
Threads per Core : 1 Unit(s)
Type : Quad-Core
Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size
L2 On-board Cache : 2x 6MB, ECC, Synchronous, ATC, 24-way, 64 byte line size, 2 threads sharing
Computer
Mainboard : Supermicro X7DWA
BIOS : Phoenix Technologies LTD 1.1b 08/04/2008
Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : 2 Processor(s)
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 8GB DDR2 FB-DIMM
Chipset
Model : Super Micro Computer 5400B Chipset Memory Controller Hub
Front Side Bus Speed : 4x 333MHz (1.33GHz)
Channels : 4
Memory Bus Speed : 2x 333MHz (666MHz)
Memory Module(s)
Memory Module : Kingston KINGSTON 2GB ECC DDR2 FB-DIMM PC2-6400F DDR2-800 (5-5-5-18 3-22-6-3)
Memory Module : Kingston 2GB ECC DDR2 FB-DIMM PC2-6400F DDR2-800 (5-5-5-18 3-22-6-3)
Video System
Video Adapter : NVIDIA Quadro NVS 440 (4 PS3.0, 3 VS3.0 250MHz, 128MB DDR 2x501MHz, PCIe 1.00 x16)
Graphics Processor
Storage Devices
WDC WD1600ADFD-60NLR5 (160GB, SATA150, 3.5", 10000rpm, NCQ, 16MB Cache) : 149GB (C:)
SAMSUNG HD103UJ (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 932GB (F:)
SAMSUNG HD103UJ (1TB, USB/SATA, 3.5", 7200rpm, 32MB Cache) : 932GB (G:)
ASUS DRW-2014L1T (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:)
HL-DT-ST DVDRAM GH22NS50 (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:)
Logical Storage Devices
System Reserved : 100MB (NTFS)
AUDIO (F:) : 932GB (NTFS) @ SAMSUNG HD103UJ (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache)
XProg-PTbup (G:) : 922GB (NTFS) @ SAMSUNG HD103UJ (1TB, USB/SATA, 3.5", 7200rpm, 32MB Cache)
Hard Disk (C:) : 149GB (NTFS) @ WDC WD1600ADFD-60NLR5 (160GB, SATA150, 3.5", 10000rpm, NCQ, 16MB Cache)
Optical Drive (E:) : N/A @ ASUS DRW-2014L1T (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Optical Drive (D:) : N/A @ HL-DT-ST DVDRAM GH22NS50 (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : Super Micro Computer 631xESB/6321ESB/3100 LPC Interface Controller
LPC Legacy Controller 1 : Winbond W83627HF/F/HG/G
Disk Controller : Super Micro Computer 631xESB/6321ESB/3100 Ultra ATA Storage Controller
Disk Controller : Super Micro Computer 631xESB/6321ESB/3100 Serial ATA Storage Controller
USB Controller 1 : Super Micro Computer 631xESB/6321ESB/3100 Chipset USB Universal Host Controller #1
USB Controller 2 : Super Micro Computer 631xESB/6321ESB/3100 Chipset USB Universal Host Controller #2
USB Controller 3 : Super Micro Computer 631xESB/6321ESB/3100 Chipset USB Universal Host Controller #3
USB Controller 4 : Super Micro Computer 631xESB/6321ESB/3100 Chipset USB Universal Host Controller #4
USB Controller 5 : Super Micro Computer 631xESB/6321ESB/3100 Chipset USB2 Enhanced Host Controller
FireWire/1394 Controller 1 : Super Micro Computer TSB43AB22 1394a-2000 OHCI PHY/Link-Layer Controller
SMBus/i2c Controller 1 : Intel 5X00/7X00 XMB Ch 21-0 SMBus
SMBus/i2c Controller 2 : Intel 5X00/7X00 XMB Ch 21-1 SMBus
SMBus/i2c Controller 3 : Intel 5X00/7X00 XMB Ch 21-0 SMBus
SMBus/i2c Controller 4 : Intel 5X00/7X00 XMB Ch 21-1 SMBus
SMBus/i2c Controller 5 : Intel 5X00/7X00 XMB Ch 22-0 SMBus
SMBus/i2c Controller 6 : Intel 5X00/7X00 XMB Ch 22-1 SMBus
SMBus/i2c Controller 7 : Intel 5X00/7X00 XMB Ch 22-0 SMBus
SMBus/i2c Controller 8 : Intel 5X00/7X00 XMB Ch 22-1 SMBus
SMBus/i2c Controller 9 : Intel 801xx/63xx SMBus
SMBus/i2c Controller 10 : IPMI T0 Controller
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Printer : ZDesigner LP 2844 (203x203, USB)
Printer : Brother DCP-7040 Printer (600x600, USB)
Printer : Brother HL-5240 series (600x600, USB)
Network Services
Network Adapter : Intel(R) 82575EB Gigabit Network Connection (Ethernet, 100Mbps)
Network Adapter : Intel(R) 82575EB Gigabit Network Connection #2 (Ethernet, 100Mbps)
Power Management
Mains (AC) Line Status : On-Line
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7600
Platform Compliance : x64
Windows Experience Index
Current System : 3.7
Old 12-26-2010, 01:17 PM
Looking at your Sandra the first thing I would do is dump the Nvidia and get an ATI.
Old 01-10-2011, 01:20 PM
mcfid's Avatar
mcfid mcfid is offline
why an ATI?????
Note for all Windows Desktops:
http://avid.custkb.com/avid/app/selfservice/search.jsp?DocId=380543
Regards
mcfid
Old 01-10-2011, 04:52 PM
Generally they seem to cause fewer -if any- problems than NVidia.
Old 01-10-2011, 05:00 PM
Word.
Since AMD bought them, they've stepped up in a big way.
NVidia has been in a lot of heat lately, and definitely have shipped some problem chipsets. I know first hand.
D
Pro Tools HD 7.3.1 crush on startup Nikis macOS 15 01-13-2014 03:13 AM
my interface make crush pt 9.0.6 papitopinillo Windows 1 01-11-2012 11:13 AM
FTP Server: Rumpus Or Crush MIKEROPHONICS Post - Surround - Video 15 05-10-2011 03:42 PM
USB 3 will crush eSata and Firewire800 dr sound Post - Surround - Video 25 03-03-2010 12:52 PM
10.5.3 crush joerusi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-29-2008 05:18 PM
