Old 12-30-2009, 09:19 AM
Blossi Blossi is offline
Default PT8.0.3 public beta Windows7 midi sync(timing) problem
Hello all
my apologies if this as been posted somewhere else,
but I've discovered a problem after installing PT8.0.3 on Win7-32 Enterprise on a Lenovo T61 T7300 @2.00 GHz w 2.0 GB RAM.
I ran the PT8 installer (as Admin in VistaSP2 mode), then installed PT8.0.3,
then the 8.0.4 drivers, after which I plugged in my MBox2 and everything seemed to be working.
Then when I set up a Click Track and hit play it doesn't keep time very well, in fact not at all.
I did test running Reason 4 in ReWire mode and had to put the buffer size to 4096, don't know if that was causing it and I also tried with EZD, the click track and the notes played by the VI's (via MIDI sent from PT) were not in time.
Any suggestions ?
cheers
Blossi
NuGen ISL AAX public beta Shan AAX Plug-ins 2 12-04-2012 03:34 PM
RX 1.31 Public Beta izotope-qa Post - Surround - Video 2 02-07-2011 09:11 AM
iZotope RX 1.31 Public Beta` izotope-qa Pro Tools TDM Systems (Mac) 2 02-04-2011 01:52 PM
Midi Timing Delay Sync Issue: MTC Sync daysean 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 01-22-2007 11:48 AM
OS X Public beta MAri 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-13-2000 06:29 PM
