Old 05-19-2002, 08:21 AM
Muzik77 Muzik77 is offline
Default Can\'t figure this one out
I'm using a Mix system at work and 001 at home. At work, PT is in some mode where the transport automatically stops after a selected region is played.
In other words, I want to be able to select a region, hit play, and continue playing until I hit stop.
I can't figure out how to do this.
Thanks in advance.
Old 05-19-2002, 08:31 AM
AE AE is offline
Default Re: Can\'t figure this one out
Do you have "Post Roll" enabled? If so, playback will continue past the specified region boundaries for the indicated time.
Old 05-19-2002, 06:06 PM
Just checked and Post roll is not enabled. ??????
Old 05-19-2002, 11:49 PM
Boom Chic Boom Chic is offline
Is your "loop playback" enabled?
Karen Basset
Boom Chic Studios
Los Angeles, CA 90048
[email protected]
http://www.boomchic.com
Old 05-20-2002, 08:56 PM
Karen,
That was it!! I always use loop playback at home while programing in midi. At work they had it off. Thanks!!
Old 05-20-2002, 11:36 PM
Don't mention it [img]images/icons/wink.gif[/img]
Glad I could help someone, I've been helped so many times by these forums.
Karen Basset
Boom Chic Studios
[email protected]
Go figure..... EvilElfBoy Pro Tools TDM Systems (Mac) 7 03-28-2009 09:53 AM
Can't figure this out! A little help would Sam C 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-09-2009 02:03 PM
I'll bet you can't figure this one out! powerjoe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-19-2005 04:26 PM
I can't figure something out. silverlode ProControl, Control|24, Command|8 1 01-19-2005 12:41 PM
Help me figure this out please... XHipHop 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-07-2001 09:52 AM
