adventures in RAID
Hi all
I thought I'd post my adventures in RAID I could use some help and I thought others could benefit as well Motivation: Old IDE hard drive died so I bought some SATA drives and wanted to try RAID (yes, I understand that its not supported by DIGI) Setup: - asus p4c800-e deluxe - 2 gb ram - pIV 3.0 prescott - HD accel with a process card - protools 6.9 - xfx dual head dvi apg - kworld xpert video capture pci card - windows xp sp2 - 2 pioneer dvd drives - 2 hitachi IDE hard drives - 2 western digital SATA hard drives Card order: - AGP video - EMPTY - HD Core - HD Accel - HD Process - PCI video capture Bus config: - primary IDE: 2 hard drives (master/slave) - secondary IDE: 2 dvd drives (master/slave) - promise SATA: 2 hard drives Before buying the SATA drives, I ran the system IDE drive on the primary IDE port, DVD on secondary IDE port, and audio IDE drive on promise IDE port in non-RAID I never had issues with this setup - it was problem free So first try: - move 2 IDE drives to primary IDE port - move 2 dvd drives to secondary IDE port - put SATA drives on ICH5R Result: IDE drives are not available in boot order menu in bios :-( I can't boot...no matter what changes I make in the bios for ICH5R It seems that SATA drives on ICH5R somehow disable or hide the IDE ports for booting (???) Anyone have this happen? Second try: - put SATA drives on Promise Result: I can boot from the IDE drive no problem - yeah! I go into the Promise Fasttrak utility and create RAID 0 array After its done, it gives the error "fasttrak does not detect proper interrupts please check your irq pcisetup and make sure the pci slot support bus master operations" WTF is that? Its an integrated chip on the mobo.... Could it be a PCI card is not sharing an IRQ or something? Look in mobo manual and slot 3 shares with SATA drives, could that be it? There is the HD accel card in slot 3 currently I continue booting into Windows and create NTFS volume on the RAID array I run a test on all drives (IDE system, IDE, RAID) with HD Tach All seems normal, RAID has an average of 20 points higher score than the IDE drives Copy a typical Protools session on to the RAID drive Start protools and once the session starts to load, it complains of something like "inacceptable audio drive for protools, do you want to copy the audio files to another location" Never seen that before... Any help appreciated Thanks! |
Re: adventures in RAID
UPDATE: Got the ICH5R RAID0 to work
After scouring the Asus forum, I found a few clues I had to follow this procedure in exactly this fashion in order to get RAID0 to work and boot from IDE primary port (any deviation and I lose the IDE from the boot order menu) - move SATA drives from Promise controller to ICH5R - update bios to 1023 - in bios, disable ICH5R and Promise Raid - reboot - in bios, select proper boot order (floppy, dvd, IDE) - reboot - in bios, go to IDE configuration - set 'onboard ide operate mode' to enhanced mode - set 'enhanced support mode on' to SATA - set 'configure SATA as RAID' to YES - set 'Serial ATA Bootrom' to Enabled - reboot Then during boot, enter Intel RAID utility Create RAID0 with 128k stripe Reboot Once in Windows, I created a basic disk and a new partition I suspect that the protools error I got initially on the promise controller is due to the fact that I created a dynamic disk with volume instead of a basic disk with partition (oops) Tonight I'll run HD Tach benchmark and try some protools sessions I'll report back tomorrow Thanks! |
Work day 1:
First - the error I got last night was "audio files are on volumes unsuitable for playback. would you like to copy them to a suitable volume?" I thought this was related to the RAID config or controller But I did a search on the digi answerbase for this and discovered that protools workspace window had this drive marked as transfer only Changed it to record and there was no more error (hehehe my bad) Ran HD Tach on the RAID0 drive off of the ICH5R Nice results....almost twice the average speed of the IDE drives Much better than the Promise RAID too Loaded a protools session with about 80 audio tracks, all session files (including audio) is on the RAID0 drive The session had enough RTAS plugs to have about 50% cpu utilization and enough TDM plugins to use about 70% of the TDM cards Hit play on the transport.... Seemed fine At one point, I did get one error message of something like "the audio cannot be retreived from the drive fast enough....defrag" This occured while protools was playing and I switched to another application in the background to do something But only happened once last night The protools interface did *seem* slight more sluggish and slower than before but its been awhile since I worked on this session from the IDE drives so I can't be sure in my comparison Given the load, it seems that the RAID0 might work ok But given the HD Tach benchmark, those much higher benchmark numbers don't seem to translate to better performance for protools Not seeing the benefit of striping of RAID0 with protools But not any worse than off the IDE drive really I'll work on this setup for a couple of days and see how it goes After that, I plan on trying RAID1 on the ICH5R That redundant config is actually more interesting to me so that I have a copy of the protools data After that, I'll try just SATA no RAID Then I'll make a decision as to which to stick with I'll report more as I have it Thanks! |
I've been working on the RAID0 setup now for a couple of weeks
Honestly it seems fine I have not run into any errors except for the first day (probably transient) I run a handful of other applications in addition to protools and no issues It would be hard to justify spending the extra cash on a RAID0 system though Even my biggest session played ok off the IDE drive This weekend I'll probably convert the array over to RAID 1 If the protools sessions work as well off the mirrored RAID setup as the IDE drive, I can see a huge advantage there I'll report back after the conversion Thanks! |
Hi all
So its been almost a month that I've been using the RAID1 (disk mirroring) on the Intel controller for my Protools sessions. No issues whatsoever. The HDTach benchmark for RAID1 was not as good as RAID0 but clearly better than NON-RAID IDE. So I'll be staying on this setup and have my Protools session drive mirrored Thus my Adventures in RAID come to an end Hope all this helps or is at least informative to someone Cheers |
Adventures in AVID Tech Support, Not Good | Tom Hartman | Pro Tools TDM Systems (Mac) | 4 | 11-10-2010 02:10 PM |
Adventures in 8-core and Magma chassis land | Top Jimmy | Pro Tools TDM Systems (Mac) | 9 | 08-21-2007 08:29 PM |
The Daily Adventures of Mixerman | Fletcher | Pro Tools TDM Systems (Mac) | 90 | 07-11-2004 11:19 AM |
On Board Raid or PCI Raid Adapter ??? | Allen Hallada | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 01-21-2002 06:16 AM |
When is a RAID really a RAID? Will this increase track count? | ThomCat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-25-2000 12:28 AM |
