Re: "Write to All enabled Shortcut" not working...
but the command works from the menu and as Eucon-Command from the S6 Automation Module.
Mac Pro 2019 16-Core, 144GB Ram, OS X 10.15 ProTools Ultimate, 2x HDX NTP Penta720 I/O + 192 HD I/O + SSL Madi Link Sync HD, Dolby Atmos RMU S6 - M40 - 32channel. Filmpost at cosmix studios vienna http://www.cosmix.at http://www.tom-kava.com |
With the transport in play, the Write To buttons in the Automation window and the buttons on my ICON work, as expected. I am getting these same behaviors in 11 and 12. |
in 10 + 11 everything is fine in both modes. I use a german keyboard but my OS X language is set to english and so is protools. but that shouldn't be an issue I think. I use this shortcut 100+ times a day when mixing...
What I see here is that none of the keyboard shortcuts (with forward slash) work, but they all work from the console (Modes > second page).
When using the keyboard, I see the Edit menu flash in blue, but nothing happens, and therefore nothing in the undo queue either.
Getting others suddenly not working as well (with 12.1), but only when using the numeric keypad. If I take the slash on the main keyboard, it works. Same situation with, for example, Trim End to Insertion: Shift-Alt 8. Works on the main keyboard, if I take the "8" along the top, but doesn't work if I take the 8 on the alpha numeric keyboard. WTF is going on! Why are these commands being changed? I'm sitting here with clients, feeling like an idiot, and work flow has ground to a halt. |
Protools shortcuts not working with OS 10.9.5
Hello
Does anyone have a problem with the F1 to F12 keyboard keys ? It only wants to do system commands. I deactivated hot corners + mission control and spotlight command and it still does it... No more Slip, Grid, Spot etc... What am i missing ? Thanks ! We're using Protools 10.3.9 HD + OS Yosemite 10.9.5 |
Re: Protools shortcuts not working with OS 10.9.5
Derek Jones Sound Engineer / Producer / Composer Derek Jones Linkedin Megatrax Recording Studios Megatrax Studios Yelp Page A-list Music Artist Page |
bump...
I have been in contact with support regarding this bug. Below is the latest answer I got from them, which shows that they are aware of the problem at least.
The workaround did not work for me unfortunately, but maybe it does for you? Hope they fix it properly soon! Quote:
Shortcut "Write Automation to all enabled parameters" on Mac Book Pro | mecderue | Pro Tools 11 | 5 | 10-06-2015 10:45 AM |
"Write To Current" KB-shortcut missing | Nicklas | macOS | 0 | 07-06-2012 02:27 AM |
How is "Automation Write to Stop" working in PT 10 | made | Pro Tools 10 | 1 | 11-17-2011 01:53 PM |
"write to all enabled parameters" shortcut not working | Eric L | Pro Tools TDM Systems (Win) | 3 | 05-05-2007 07:49 AM |
Looking for "Write to All Enabled Parameters" LE equivalent | CCash | Pro Tools TDM Systems (Mac) | 1 | 05-15-2002 05:39 PM |
