Old 05-04-2014, 10:42 PM
gonsdeejay's Avatar
gonsdeejay gonsdeejay is offline
Default Re: PT 11.1.3 - Bizarre plug-in behavior
Hi Dave....Try To set your Audio Interface as Core Audio....instead of Aggregate I/O.. and check again....
Pro Tools 2021.12 UAudio Apollo X8, 8 Duo & Apollo Twin. Mac mini M1 8 on Ram, 256gb, Thunderbolt 3 KRK V88. Yamaha HS7 Korg ESX-1 MBOX2 003Rack Producing My Own Life
Old 05-05-2014, 07:49 AM
Farmer Dave Farmer Dave is offline
I've tried multiple Playback engines - thanks though.
Old 05-05-2014, 12:04 PM
Tomy DeClerque Tomy DeClerque is offline
same thing with AIR delay ... after saving, reopening the session ... it stuck to 500 ms ...
tOMY
Old 05-05-2014, 12:22 PM
The workaround is to set the tracks to READ instead of OFF, and write automation to the entire area. I can work with this, but there's no reason I shouldn't be able to work with automation set to OFF for a "set and forget" setting.
In fact automation OFF is really dangerous with this behavior.
Old 05-05-2014, 02:19 PM
connor@@vid's Avatar
connor@@vid connor@@vid is offline
I can still reproduce in READ with EQuick. Can you list the steps you're taking exactly that avoid the issue? Thanks!
In any case, this is now under investigation.
Old 05-05-2014, 02:23 PM
I just select the entire range on the track I want to affect and automation "Write to all enabled", making sure first that the settings are where I want them. After that, in READ it seems to work.
I haven't verified several times, but it worked after re-launching the session a couple of times here.
Old 05-05-2014, 06:49 PM
Danny Caccavo Danny Caccavo is offline
Connor, this is PTSW-194042. The AIR multi delay is PTSW-194045
Old 05-05-2014, 06:54 PM
Intransit Intransit is offline
Want to keep track of this. Is it only multi mono plugs??
iMac Retina 5K, 2020, 3.6 GHz 10-Core Intel Core i9, RAM 72GB
HD Native PCIe card /// OWC Mercury Helios 3S
PT 24.3.0
Old 05-05-2014, 09:25 PM
Already watching them and collating the list of known affected (so far) 3p plug-ins into the bug for this one. Thanks, to both of you, for the clear repro steps. We're on this one.
Old 05-05-2014, 09:51 PM
Thanks!
Edit window - right/left arrow keys - bizarre behavior Londoner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-05-2010 05:47 AM
Akai MPD26 creating some really bizarre PT click behavior Jonny Jon Jon MIDI 0 05-07-2010 12:48 PM
PTHD for Windows -- bizarre Edit Window behavior jjnyc Pro Tools TDM Systems (Win) 4 12-09-2007 06:53 PM
Bizarre behavior on D-Control Mikey MTC ICON & C|24 2 02-12-2007 10:09 PM
Bizarre Premiere 4.2 Behavior JKD99 Post - Surround - Video 8 02-20-2004 09:27 AM
