Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 03-07-2021, 06:37 PM
oldskool oldskool is offline
Default smooth clip gain edit transitions?
I thought that there was a new way to smooth abrupt clip gain transitions. But I can't find it anywhere. Can anyone point me to the command that smooths 90 degree transitions in the clip gain line?
I hope I didn't just imagine that this exists. I love clip gain, but I hate the little clicks in the audio that it introduces.
Old 03-08-2021, 03:18 AM
Sonopolis Sonopolis is offline
Default Re: smooth clip gain edit transitions?
CTRL+shift+x will make a ramp even without the clip gain line visible
Old 03-08-2021, 03:30 AM
Will Russell's Avatar
Will Russell Will Russell is offline
according the the shortcuts doc Control+Shift+X is Cut Clip Gain
Will Russell
Electric Wilburland Studio
https://linktr.ee/wilburland
M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock
M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS
Old 03-08-2021, 08:13 AM
I usually just option-click with the smart tool to remove the breakpoint at the corner of the right angle. But I am usually doing a lot of fine tuning of dialog using clip gain and the smart tool, and I rarely just highlight a section and trim it up or down, in part because of the right angles.
Scott Gatteño
Old 03-08-2021, 09:35 AM
Sometimes, adding a cross-fade can smooth volume transitions
Old 03-08-2021, 09:10 PM
As Dave points out, if you're using clip gain on a per-clip basis (which is the only way I'll use it) then short equal-gain xfades at the clip transitions will prevent clicks.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 03-09-2021, 01:02 PM
Thanks Rich, and Dave. I actually didn't understand Dave's suggestion, but the way you (Rich) explained it makes it clear. From now on I'll separate clips before applying clip gain.
Selecting a clip in Edit window fails to select clip in Clip List oldskool Pro Tools 2020 8 09-28-2021 01:43 AM
Edit all clip gain on one track that has splits? Thenewexhibit Pro Tools 12 2 02-16-2017 04:42 PM
AudioSuite Gain/Normalize also on Clip Gain A-n-d-i macOS 0 03-13-2014 12:46 PM
Clip gain on clip groups: bug or feature? idris Post - Surround - Video 6 01-02-2013 10:48 PM
Smooth out Automation Transitions Dizzi45Z Pro Tools TDM Systems (Mac) 0 03-01-2012 07:40 PM
