M-Audio Fast Track C600 causes Blue Screen due to driver failure.
I recently purchased a brand new Fast Track C600 series audio interface. After having installed it on my computer as per the instructions, I continue to constantly have blue screen of death errors on my PC every time I attempt to access it in my DAW. It has happened with every DAW I have tried, fom Cubase 5 to Acid Pro 7 to Audacity to the Protools SE that came bundled with it. I have a bit of knowledge about computers so I have tried all the common fixes. I have installed the latest drivers, run the PC optimizations on Avid's website, and I was so frustrated I even went so far as to COMPLETELY reinstall Windows 7 Professional SP 1 on my computer from scratch. I have a picture of the BSOD attached to show. I had extremely high hopes for this little interface that claims to do it all but so far my experience has been quite horrid. It crashes like I said and both M-Audio and Avid do not have readily available support for this interface, despite it being merely a few months old. I know the drivers for this interface are on Avid's site but I could not find a support forum there for the Fast Track so i decided to post to Pro Tools 10, which seems to be the DAW most users are using this interface with. I would really appreciate any support because as of now it seems I've just purchased a really expensive paperweight.
Re: M-Audio Fast Track C600 causes Blue Screen due to driver failure.
I forgot to attach my PC specs from Sandra so here they are:
SiSoftware Sandra complete report ID Host Name : Studio_PC Workgroup : WORKGROUP Computer Model : GigaByte P67A-UD3-B3 Chassis : GigaByte Desktop Mainboard : GigaByte P67A-UD3-B3 BIOS : Award (OEM) F2 02/22/2011 Total Memory : 8GB DIMM DDR3 Processors Processor : Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz (4C 8T 3.39GHz, 3.4GHz IMC, 4x 256kB L2, 8MB L3) Socket/Slot : FC LGA1155 Chipset Memory Controller : Intel Core (Sandy Bridge) DRAM Controller 100MHz, 2x 4GB DIMM DDR3 1.33GHz 128-bit Memory Module(s) Memory Module : Kingston 9905403-174A00LF 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Kingston 9905403-174A00LF 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Kingston 9905403-174A00LF 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Kingston 9905403-174A00LF 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Video System Monitor/Panel : Dell Computer DELL D1028L (1280x1024, 14.9") Monitor/Panel : ACR H213H (1920x1080, 30.2") Video Adapter : NVIDIA GeForce GTX 580 (16CU 512SP SM5.0 1.54GHz, 1.5GB 4GHz 384-bit, PCIe 2.00 x16) Video Adapter : NVIDIA GeForce GTX 580 (16CU 512SP SM5.0 1.54GHz, 1.5GB 4GHz 384-bit, PCIe 2.00 x16) Graphics Processor OpenCL GP Processor : NVIDIA GeForce GTX 580 (512SP 16C 1.54GHz, 1.5GB 4GHz 384-bit) Compute Shader Processor : NVIDIA GeForce GTX 580 (512SP 1.54GHz, 1.5GB 4GHz 384-bit) CUDA GP Processor : NVIDIA GeForce GTX 580 (512SP 16C 1.54GHz, 768kB L2, 1.5GB 4GHz 384-bit) Storage Devices Hitachi HDS723020BLA642 (2TB, SATA600, 3.5", 7200rpm, 32MB Cache) : 2TB (C:) (D:) (M:) Multi Flash Reader (USB2) : N/A (F:) ATAPI iHAS124 B (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:) ELBY CLONEDRIVE (SCSI, SCSI-2, BD-R, HD-DVD-R, DVD-R, CD-R, 256kB Cache) : N/A (G:) Logical Storage Devices System Reserved : 100MB (NTFS) MusicDrive (M:) : 391GB (NTFS) @ Hitachi HDS723020BLA642 (2TB, SATA600, 3.5", 7200rpm, 32MB Cache) Hard Disk (C:) : 542GB (NTFS) @ Hitachi HDS723020BLA642 (2TB, SATA600, 3.5", 7200rpm, 32MB Cache) Data (D:) : 930GB (NTFS) @ Hitachi HDS723020BLA642 (2TB, SATA600, 3.5", 7200rpm, 32MB Cache) Removable Drive (F:) : N/A @ Multi Flash Reader (USB2) Hard Disk (Q:) : N/A Optical Drive (E:) : N/A @ ATAPI iHAS124 B (SATA150, DVD+-RW, CD-RW, 2MB Cache) Optical Drive (G:) : N/A @ ELBY CLONEDRIVE (SCSI, SCSI-2, BD-R, HD-DVD-R, DVD-R, CD-R, 256kB Cache) Peripherals LPC Hub Controller 1 : Gigabyte P67 LPC Controller LPC Legacy Controller 1 : T2 87-28 Audio Device : Gigabyte Cougar Point High Definition Audio Controller Audio Device : nVidia GF110 High Definition Audio Controller Audio Codec : nVidia Riva 128 Graphics Accelerator [NV3] Serial Port(s) : 1 Disk Controller : Gigabyte Cougar Point 4 port SATA IDE Controller Disk Controller : Gigabyte Cougar Point 2 port SATA IDE Controller USB Controller 1 : Gigabyte Cougar Point USB Enhanced Host Controller #2 USB Controller 2 : Gigabyte Cougar Point USB Enhanced Host Controller #1 USB Controller 3 : Gigabyte Renesas Electronics USB 3.0 Host Controller FireWire/1394 Controller 1 : VIA VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Printer : Canon MX7600 series Printer (Colour) Printer : Canon MX7600 series Printer (Colour) Printer : Canon MX7600 series FAX (200x200) Printer : Adobe PDF Converter (4000x4000, Colour) Scanners and Cameras Scanner : WIA Canon MX7600 ser_000085CEBFD4 (Scanner, USB) Peripherals Network Services Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 100Mbps) Wireless Adapter : Ralink RT61 Turbo Wireless LAN Card Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64 |
Also check in Device Manager to see if another device is sharing the same IRQ. You can choose to list devices by connection and view resources there also. You may find a shared IRQ or memory address. As far as I know two devices should not be sharing memory addresses. I believe the FFFFF address is the actual memory range mapped to that device.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
I'm having the same problem. Whenever I begin using, playing notes through the midi in Cubase 8 with the Fast Track C600 as the playback device/ audio interface my XPS 3.10 Ghz 8.0GB RAM crashes and shows the Blue screen.
Any solutions or obvious fixes for this problem? |
please, question about avid-m audio fast track c600 | katerinacyprus | Getting Started | 3 | 08-18-2015 02:07 AM |
Fast Track Ultra 8R Blue Screen of Death... | Jasonlidel | FireWire & USB Audio Interfaces (Win) | 0 | 07-07-2013 12:29 PM |
Fast Track C600 | muk786 | FireWire & USB Audio Interfaces (Win) | 6 | 04-05-2013 06:48 PM |
11R and Fast Track C600 | Platereverb | Eleven Rack | 8 | 03-03-2013 03:37 AM |
M-Audio Fast Track C600 - new interface | nst7 | Pro Tools 9 | 10 | 03-13-2012 09:57 AM |
