  #21
Old 02-13-2015, 01:27 PM
Default Re: Only hearing music out of the left headphones
Originally Posted by MusicGirl View Post
And be sure to default the IO as suggested.
Yes, I started a new session and I dragged the MP3 over in pro-tools pushed play and it still only plays out the left hear!
I defaulted all the settings!
Cables and headphones: (Sony)Headphones. Regular mic (Cable)
But are the headphones working right? Cables on those things fail all the time.
Do you have the PT11 demo session and if so have you tried playing it and does it sound okay (sound out of both left and right channels?
Jack
QAPLA!
  #22
Old 02-13-2015, 01:48 PM
MusicGirl's Avatar
MusicGirl MusicGirl is offline
Hey, thanks trying to help me! Where do I listen to the PT11 demo session?
-MusicGirl
  #23
Old 02-13-2015, 02:00 PM
Don't waste time on that, you already have got beyond needing to do that.
So the very simple question you should work on answering is if you plug the headphones into something entirely different do that work OK in both ears?
  #24
Old 02-14-2015, 04:53 AM
Have to disagree with you. The demo session will at least point out that all the hardware part is working or not. At this point we don't know that it does. She needs a known working benchmark PT session.
MusicGirl:
The PT11 demo session is available for download from your Avid user account.
Jack
QAPLA!
  #25
Old 02-14-2015, 09:57 AM
Originally Posted by musicman691 View Post
Have to disagree with you. The demo session will at least point out that all the hardware part is working or not. At this point we don't know that it does. She needs a known working benchmark PT .
She just created a new session, dragged an audio file to it and had the same problem. That is the test. Now is it a better idea to repeat that with a demo session or to unplug the headphones and uh do something as difficult as plug them into a mp3 player/CD player/home HIFi/anything else just to check they actually work.
If they don't well it is obvious, if they do then likely the interface is faulty and contact Focusrite support.
  #26
Old 02-14-2015, 11:09 AM
Park Seward's Avatar
Park Seward Park Seward is offline
Tough to help out when she won't tell us what interface she is using.
My last attempt. View these videos.
https://www.youtube.com/watch?v=XDKv2T6og0M
https://www.youtube.com/watch?v=cRbAsXtPSLE
https://www.youtube.com/user/FocusriteTV/videos
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
  #27
Old 02-14-2015, 02:38 PM
The reason I keep mentioning to use the demo session is it's a known quantity with routing and such and apparently the op doesn't know a heck of a lot about what she's doing with PT. She may be having routing issues or just not plain understand things like the rest of us do. It's a simple download and would be worth the time.
Where'd you see anything about Focusrite? I don't recall seeing that here. We don't know all that much about her system.
Jack
QAPLA!
  #28
Old 02-15-2015, 04:44 AM
xylie6 xylie6 is offline
Have you used the headphones anywhere else lately? Do they work OK?
I would try using a separate headphone to listen with also. Make sure the plug is pushed in all the way to the jack. If it is not, It could cause what you are describing.
  #29
Old 02-15-2015, 11:18 AM
She said, "I have a Focusrite Audio Interface". If so, she should be using their software called "MixControl". Their software can place a mic on a channel and have it come out of the headphone jack without even having Pro Tools on. One of the videos I selected shows exactly how to do that. There is another one that explains why you might hear the mic on only the next channel.
Park
  #30
Old 02-15-2015, 11:24 AM
Default Only hearing music out of the left headphones
And since there appears to be no playback at all happening in the right earphone, the *first* thing to do is simply check if the headphone/cable/connector seem OK. Test them elsewhere.
hearing vocals in headphones mgsr70 macOS 16 12-09-2012 11:16 PM
Hearing vocals in headphones as i am recording it. abikambic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 01-19-2012 07:11 AM
Hearing sound through headphones, but no visible signal in PT 8 LE Alexthepirateguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-16-2010 05:44 PM
Hearing pops in headphones macbox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-23-2010 12:10 AM
keeping recording levels, but not hearing through headphones badperson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-02-2002 10:31 AM
