Update old Pro tools system
Hi, I'm looking to update an old HD3 system and I'm finding out I'm out of options, can you please help to find the optimal solution? I'm doing simple film 5.1 mixing.
I currently have, simplified: Mac Pro G5 with HD3 system (1 core + 2 accel PCI cards) 192 I/O XMON Icon D-Command +expansion I would like to keep using the trusty 192 I/O and of course the D-Command since they work perfectly fine. My idea was to get a pumped up "cheesegrater" Mac Pro or a Hackintosh but I just found out avid discontinued the HD native PCIe card . I don't want to invest in an HDX system and I'm very reluctant to go the thunderbolt route that forces me to buy a apple trashcan. Also the new Pro tools naming scheme confuses me. Do I need Ultimate to mix in 5.1 with the D-command? Thank you in advance! |
Re: Update old Pro tools system
You can get used HD Native PCIe cards on eBay. But I don't think staying in the cheesegrater ecosystem is a good investment at this point.
Get a refurb trashcan. You'll be stunned by how fast it is, and you'll have money left over to invest in the new Mac Pro that theoretically comes out next year. Even a 4-core trashcan will have enough processing power to be an upgrade over your HD3 system. 6-cores are the sweet spot though. Yes, you need Ultimate to mix in surround and to use an ICON. Good luck!
Nathaniel Reichman Producer/Re-recording Mixer - New York Nathaniel Reichman | IMDB | LinkedIn |
"Do I need Ultimate to mix in 5.1 with the D-command?"
YES. As long as you have HD9 or HD10 you can get your license reinstated. Ultimate will work with other i/O's but for your rig, HDX-1 will closest resemble the HD3. Avid may still bee offering an exchange upgrade. Otherwise Reinstate and get a used HDX card or HD Native card. Note: Avid now requires a DIGI-Link license (Included with reinstatement) or keep this in mind if buying just the Ultimate asset.
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit Last edited by DetroitT; 07-10-2018 at 07:28 AM. |
Hi Thanks for the replies
It's not that easy to find used HD Native PCIe cards in my country, not even in europe and a refurb trashcan starts at 2300$, way to expensive for a failed concept. I think I must say goodbye to the 192 I/O. "thanks", avid What are the main drawbacks of going the "third party" route? Let's say I get a RME UFX II or similar. I don't do critical tracking so extreme low latency is not a must. Stability is key however Cheers |
Re HD/Native Thunderbolt, There are currently a few PC motherboards with Thunderbolt, so you could build a hackintosh with one of them(or consider a switch to Windows)
Hi, thanks for the replies,
I found out I can get a Hackintosh professionally built and configured with TB3 interface. Cheaper than a refurb trashcan and more CPU power This will allow me to use HD Native TB and additionally use a aja or blackmagic video output card via PCIe which I need for post. I hope the plan works out well! |
Steve
Steve Shepherd Extreme Mixing |
Hi Nucelar.
Keep us posted on whatever Hack your guy gets working. We have tried several T-bolt motherboards over here and had nothing but problems and disconnections. Luckily for us, T-bolt is not a requirement right now.... The time we spent being down was a problem though, and had I known better, I would have gotten a refurbed trashcan like the above poster recommended. (He always has really good advice by the way) Hacks are like owning a European motorcycle.... When they run, they scream. When they don't, you scream.
bookerv12 |
Plug in update Pro Tools 6.4.1 for mix system - link not working | aeos | Pro Tools TDM Systems (Win) | 1 | 10-20-2015 02:16 PM |
System ID / Update | Adam Christopher | General Discussion | 17 | 05-08-2015 07:19 AM |
System Configuration for Pro Tools 10.3 update | twistiejoe | Avid Scorch (iOS) Forum | 2 | 10-13-2012 01:14 AM |
10.5.6 update. Is it safe to apply the system update from 10.5.5? | SBCCMusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 02-02-2009 02:27 AM |
Need To Update My System... | jumpnblues | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-14-2007 04:43 PM |
