Old 06-17-2020, 02:48 AM
stargazer stargazer is offline
Default HDX-card, Radeon RX 580 8GB and power consumption
I have an HDX card in my MacPro5,1.
Looking at a ”Radeon RX 580 8GB Graphics Upgrade for Mac Pro 2010-2012”.
https://macpatric.com/products/amd-r...62c29d8b&_ss=r
The graphics card needs both of the two connectors on the motherboard. (PCIE AUX A / PCIE AUX B), but the HDX card uses the first one.
Anybody with a similar setup and a solution?
PT Ultimate 2022.10.0 | HD OMNI | S3 | PT Dock | EuControl 2022.4.0.78 | PT Control 2022.4.0.60
macOS Big Sur 11.6.5 | Mac Pro (2019), 3,2 GHz 16-Core Intel Xeon W, 384 GB 2933 MHz DDR4
Old 06-17-2020, 11:52 AM
AE AE is offline
Default Re: HDX-card, Radeon RX 580 8GB and power consumption
in my (admittedly hazy) recollection i believe i sold the graphics card that was supplied with my MP and replaced it with a card that only required a single power connection. i don't recall that there was an option that supported the upgrade you're looking at.
Old 06-17-2020, 01:20 PM
Searched this forum, but got more confused...
Some possible solutions I can think of:
1. Compatible graphics card that supports 3840x2160 that only needs one power cable.
2. Expansion chassis.
3. External power for the graphics card.
4. Share one of the connectors (PCIE AUX A or PCIE AUX B) if there is enough power for both cards.
5. eGPU (But I guess there is no way to install that on a MacPro5,1)
Old 06-17-2020, 01:52 PM
AE AE is offline
i ended up with the Radeon HD 5770; works fine driving two monitors but only at 1920 x 1080.
Old 06-17-2020, 02:13 PM
Is the Radeon HD 5770 Mojave compatible (Metal)?
What’s the solution if you run only one display?
Old 06-17-2020, 02:27 PM
JFreak's Avatar
JFreak JFreak is offline
No.
Janne
Old 06-17-2020, 02:51 PM
Ok, thanks!
Old 06-20-2020, 06:41 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Hi. I use the 580 mac video card.com flashed
The two mini 6pin pcie power to 8 pin video.
Power split / spliced to avid 4 pin hdx
2-evo ssd’s, 2-10tb spinners
Hdx1
I’ve been using this split 8 yr or so since the
Original 5870 card, 7950 now the 580
Mac video cards also offers a single power cable solution (6 pin to 8 pin)
Old 06-20-2020, 08:44 AM
Thanks DetroitT!
I’m gonna contact Mac Video Cards.
Old 06-24-2020, 02:40 AM
Are there any Mojave compatible graphics card that only needs one power cable available?
HDX card power consumption stanonbass Pro Tools HDX & HD Native Systems (Win) 0 05-14-2016 10:05 AM
Mix Card Specs , Power Consumption??? Table Syrup Records Digidesign Hardware & Software 1 08-11-2010 09:43 AM
Mbox 2 power consumption? How much of a power load is this spaids 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-30-2007 06:27 AM
power consumption of a HD core card? black030 Pro Tools TDM Systems (Win) 3 03-16-2007 09:18 PM
Power Consumption dloeliger VENUE Live Sound Systems 1 03-06-2007 09:13 AM
