Old 01-11-2017, 06:22 AM
Bushpig Bushpig is offline
Default Re: Pro Tools, Virtual Instruments and Program Changes
MM,
but with someone else in the room I sometimes get distracted mainly because I get worried about them mucking about with stuff they shouldn't.
Ha! Yeah, the children in the playpen.
I do like the idea of splitting out MIDI controller data which is like splitting out MIDI'ed drums to separate tracks (snare, kick, etc.)
That's actually a very good analogy! I never thought of it that way, but of course, that's exactly what it is. Mind if I steal it?
Cheers.
SB
2 x Systems: MacPro 5.1 (Nehalem) 2 x 2.26 Quad Core, OSX 10.9.5 (Mavericks), PT10.3.10HD, 32 Gig RAM, PCIe HD3, 192's, Sync I/O, Midi I/O.
Old 01-11-2017, 02:24 PM
Originally Posted by Bushpig View Post
MM,
Cheers.
SB
Go ahead my friend - use as needed in good health
Jack
QAPLA!
Old 02-05-2017, 08:51 AM
hanstondo hanstondo is offline
using uacc and program change to control articulations does work well in protools.
if you manually insert a program change in protools, with bank to zero, and correct cc32 value in upper right corner of the dialogue box,
Kontakt will switch to the correct articulation.
Easy setup is using touch osc, with the template for spitfire, or other libraries: you can switch articulations with the app, but protools doesn't allow you to record them live. But you can insert a program change manually, and when the dialogue box opens, you just push the correct articulation on the touch osc app, and the correct articulation will be in place as program change. You only can't read which articulation it is, since it will be called 'bank' (double click the program change inserted will open the dialogue box, you can see in the upper right corner the cc32 value, which will correspond to the uacc list.
Old 02-05-2017, 09:12 AM
What is uacc? Google provides nothing music-related. Seems like according to your explanation it's needed to get Kontakt to respond to embedded program changes in the MIDI stream. All I know is without it Kontakt does not see program changes.
Or are you talking about articulation changes? Those usually are taken care of by MIDI notes.
Jack
QAPLA!
Old 02-06-2017, 05:58 AM
UACC = Universal Articulation Controller Channel (alternative for articulation switching with key switches : using cc32 - dedicated for program changes)
info on this blog: http://www.syntheticorchestra.com/blog/?10
  #16
Old 08-15-2020, 04:27 AM
cmbourget's Avatar
cmbourget cmbourget is offline
Originally Posted by DonaldM View Post
One thing you might consider doing is set up a separate track for keyswitching only and send it to whatever instrument you want the keyswitch to affect. So, you have one MIDI track playing the instrument and a separate one just for keyswitches to change articulations for that instrument. That way, when you want to look at or print a score, you can just make the keyswitch tracks inactive.
Good !
  • Pro Tools 2023.12 Studio, Nuendo 12, Samplitude Suite Pro X7, Wavelab 11, Dorico Pro 5, Melodyne studio 5.
  • Apollo X 16 and 7.1.4 studio (Focal Solo6 be, Sub, and Focal EVO)
  • Softube Console 1. UAD systems (USB3).
  • Mac Studio M2 Ultra 2023. 2T. 128 Go. + 2X 4 T NVMe ext.
  • AMD Ryzen 9 5950X 16-Core Processor 3.40 GHz 64 Go, full SSD
  • Roland V-Piano, Novation 88
  • Etc.
  • www.claudemarcbourget.com
  #17
Old 08-15-2020, 04:39 AM
Marsdy Marsdy is offline
AFAIK Spitfire is the only developer to adopt UACC. It was their brainchild so not surprising.
Kontakt will respond to program changes either using the built in Multi script and I think the Quickload function responds to program changes although I’ve never used it.
The best way to manage articulations in any DAW is an app like MIDI Kinetics Composer Tools Pro.
Dave Marsden
UK
  #18
Old 08-15-2020, 04:47 AM
Long time Kontakt user and I've never figured out how to get it to respond to program changes. Shouldn't matter whether you use the Quickload or not. All the QL does is to reference the same locations that are in the browser that can extend to the left of the gui.
Jack
QAPLA!
  #19
Old 09-22-2020, 06:27 AM
Lauro Lauro is offline
I hope this helps:
https://www.youtube.com/watch?v=nw_nFNHl6ho&t=162s
https://www.youtube.com/watch?v=fVSiUaJGsos&t=39s
Good music to everybody
Lauro
  #20
Old 09-24-2020, 04:37 AM
Originally Posted by Lauro View Post
Having audio to go with the video would have been nice
Jack
QAPLA!
Pro Tools 11 Virtual Instruments MasonDC Windows 1 07-17-2014 04:39 PM
Program Change and Virtual Instruments?! blackdognove Windows 0 10-19-2013 09:31 AM
New to Virtual Instruments in Pro Tools amayhem Virtual Instruments 4 11-08-2009 06:17 PM
Virtual Instruments for Pro Tools 6.4.1 on Mac OSX hotbeatz Pro Tools TDM Systems (Mac) 0 02-21-2008 12:42 PM
Virtual Instruments in pro tools at last! TheVectorWarrior 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 11-11-2001 11:46 AM
