Pro Tools TDM 6.4cs8 Update
Pro Tools 6.4cs8 for Pro Tools|HD & Pro Tools|HD Accel systems is now available for download from the CS Index page:
http://www.digidesign.com/download/cs/ Linked at the top of the Support->Downloads section under Featured Downloads. These updates are recommended for all HD users with Pro Tools 6.4 TDM software, in addition to the separate 6.4cs6 Plug-In Update available from the same index page. In addition to all previous fixes from 6.4cs1 through cs7, these 6.4cs8 releases include these fixes: Pro Tools TDM 6.4cs8 for Mac OS X adds the following: Fixed: When Using Pro Tools in +12 dB Fader Gain Mode, the Level on Bus Paths or Hardware Outputs Could Be Incorrectly Increased by 6 dB (Item #51907)
Administrator Avid Pro Audio Community |
Re: Pro Tools TDM 6.4cs8 Update
DIGI-
When I updated to version 6.4cs8, my version is still 6.4cs7 (Modified August 12) Am I downloading the wrong version? Thx
Dean |
That is correct, the Pro Tools application itself is not updated if you had previously installed cs7.
From the download page and the Read Me: Quote:
I checked the cs update page and it specifies for Mac OS 10.3.2 or 10.3.4. Since I am running 10.3.3, does this mean I do not the update or does it mean 10.3.2 thru 10.3.4?
This is from the compatibility documents: 10.3.3 has not been fully tested with Pro Tools, will not be further tested, and is not recommended I hope this clears things up for you you can find this information here: http://www.digidesign.com/compato Thanks, Digidesign Tech Support |
I have already (foolishly it seems) done the Mac OS update to 10.3.5 and I have since experienced some Firewire drive issues. In my case it wasn't a Pro Tools specific problem but a basic system issue... certain firewire drives consistently un-mounted themselves for no apparent reason. I was left with the Mac OS error message about dissconnecing firewire drives withpout first properly unmounting them. Is this what Digidesign refers to in their warning about 10.3.5?
What is the best way to restore my system to 10.3.4? Can I just run the 10.3.4 updater on top of the 10.3.5 system? Or do I have to do a fresh install? Any thoughts swould be greatly appreciated! maxx [email protected] |
My G5 came with OSX 10.3.5 what am I supposed to do? I've already installed PT 6.4 and it seems to be working OK?
sit tight i'm using it
and it's working fine make sure you enclosure has the latest firmware firewire is not that cool right now us it for backup til they digi or apple get it happening those two need to go to club med for a week to get to know each other better
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
Im running 10.3.5 on a G5 dual 2ghz hd accel 2. No problems whatsoever. Firewire or otherwise... Just in case you want to give it a shot julien-k.
--E http://www.ericmilano.com |
PT MP 7.4cs8 Update question?? | tha]-[acksaw | Pro Tools M-Powered (Win) | 6 | 12-22-2008 09:06 PM |
Pro Tools 7.4cs8 Updates | Avid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-25-2008 04:34 PM |
Pro Tools 7.4cs8 Updates | Avid | Pro Tools TDM Systems (Win) | 0 | 11-13-2008 04:44 AM |
Pro Tools TDM 6.4cs8 Update | Avid | Pro Tools TDM Systems (Win) | 0 | 08-24-2004 06:20 PM |
Pro Tools TDM 6.4cs8 Updates | Avid | General | 0 | 08-24-2004 06:14 PM |
