  #21
Old 10-31-2014, 02:50 PM
April.nettles17 April.nettles17 is offline
Default Re: I can hear my mic, just not in ANY DAW!!! Just started happening... please help!!
So went back in to my system sound options and I disabled the mbox line 1/2 under the recording tab. I then restarted my pc... Went into fruity loops and set the input to analog 1.... I got nothing. set the input to analog 2....and got a small reading in the fader however it's reading stereo. I armed the track pressed record scream into the mic and the input signal moved a little bit but never about a certain point... no matter how loud i got.. I played it back and turned the mix know hard right and i could hear myself a little. Now I'm loading pro tools to try it there. But my question is why is the signal so low and why am I only getting one when I switch to input 2 and why is it reading stereo? Okay no signal at all in pro tools.
By the way I know that the mbox comes with it's own dedicated asio drivers, I was just trying anything cause I was so frustrated... Asio4all wasn't on the pc when this problem started and I just tried it last night. I have already uninstalled it.
  #22
Old 10-31-2014, 03:28 PM
SpinningDisk's Avatar
SpinningDisk SpinningDisk is offline
Dont give up my man. Have you had the opportunity to try on another friends machine? I noticed that you did with the original owner but?
PT 11, PT LE 6.0, DIGI 001, DIGI 003, 27" Late 2012 Intel iMac, Blue and White G3, Reason 7, Celemony, Waves, A.I.R., Softube, XLN Audio, IKmultimedia, Massey
Alesis Masterlink, Alesis Adat LX20,
, Yamaha Motif ES8, Sure SM58, Sure KSM27, Byerdynamic MC 834 N, Event Project Studio 6, Pod Line 6, Focusrite Trakmaster Pro DI, Glyph Drives, Lexicon,
Fender Strats, Ibanez Acoustic, Ibanez Bass, Ibanez Electric.
http://www.johnackermusic.com/
[email protected]
Live and Let Live
  #23
Old 10-31-2014, 03:50 PM
mesaone mesaone is offline
You don't want to disable the MBOX in Windows sound settings. You do want to set your built in Audio as the default - which is not the same as disabling the Mbox.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
  #24
Old 10-31-2014, 04:05 PM
popajoe popajoe is offline
yes you do for now just to see if there a green one there other than the mbox min that's all iam looking for. mesaone your correct i just don't know if it's there.
  #25
Old 10-31-2014, 04:09 PM
Once you disable it, Windows ceases to see it. So, if you actually want to use the device, leave it enabled. As you can see from his post, it didn't work.
Setting to default and enabling are two different things.
  #26
Old 10-31-2014, 04:13 PM
mjslakeridge's Avatar
mjslakeridge mjslakeridge is offline
On your Sandra report, two problems stand out. First, your memory modules are not the same and the timings are mismatched. Second, it looks like you only have one hard drive. Pro tools requires a separate hard drive for recording audio to. Also the processor is a bit underpowered. You may be Ok for smaller sessions. But none of these observations are likely to be the cause of your problem with the microphone.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ
Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit.
  #27
Old 10-31-2014, 04:15 PM
System Audio settings
Driver installed.
https://www.dropbox.com/s/szxv2zmhot...85846.jpg?dl=0
https://www.dropbox.com/s/2bsck0ayeq...85919.jpg?dl=0
https://www.dropbox.com/s/f53fwn3jjp...85926.jpg?dl=0
This is what's happening in FL10 no signal input 1
https://www.dropbox.com/s/6wj3zogdmt...90000.jpg?dl=0
Signal input 2 but in stereo very small signal doesn't move pass where it is well just a little...very little.
https://www.dropbox.com/s/pa0uxr1zyt...90027.jpg?dl=0
  #28
Old 10-31-2014, 04:21 PM
I really appreciate everyone's input on this matter... I am really trying to take everyone's advice and apply it. Also I am trying to provide the correct information the best way I can..... I don't want to give up....this gal won't give up.
  #29
Old 10-31-2014, 04:26 PM
Originally Posted by popajoe View Post
hi' it look like your mixer for mbox is not set up correctly open it whit no daw open .\
Under software returns push up 1-2 volume to 0 an master vol up to 0 .
With this mbox 3 mini on it's own control panel I can't select anything except the sample rate and the buffer size.
https://www.dropbox.com/s/lcu25y7h0o...92529.jpg?dl=0
  #30
Old 10-31-2014, 04:27 PM
Driver installed.
ok your FL .alm on FL now.
WHAT audio divice you have sected make it avid mbox asio/ 44.1/24 point
on audio planl.
on mixer look right make srure there no green check in OS sound card in mic of mbox
dell wow go there to get each updates for your dell do them all.
Can't hear track I'm recording on but can hear all others Durstlaw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 19 12-14-2022 01:24 PM
Can't hear anything.. Gibslpsg Pro Tools M-Powered (Win) 1 09-21-2008 01:03 AM
OT: Hear Technologies Hear Back Matt Whritenour 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-16-2004 05:58 PM
Let me hear your digi 001,Post your music that you record hear optymusblu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-05-2003 12:52 AM
Let me hear what your 001 can do feedoler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 03-13-2001 03:34 PM
