\"record audio volume\"
Hello, I am brand new to protools and when I try to start a new session and click "save" on the the sound parameters window I get a message sayin "session must be on an audio record volume". What does this mean and how to I change this? tried changin the input volume on my computers preferences, but still got the same message. Your help is appreciated!
Re: \"record audio volume\"
hi. welcome to the forum.
as it explains in you manual, the drives that you record onto must be marked "R" in the WOKSPACE window. T is transfer, P Playback... make sure you have 'permissions' on that dive to change it. ... meaning, that is an OSX thing. dig, daddio?
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
did that and i got a message sayin the drive cannot be designated as an audio record volume because it is not a valid audio volume... ???? i still dont know what its talkin about
yer not trying to do this to your system drive are you?
how is the drive formatted? do have permission? highlight the drive, then hit apple-i (get info) look at permissions ... make sure that the account you are logged into in the OS is allowing you to change the permission on the drive so you can reand and write to it.
the only drive i have available is the system drive. is this wrong?
get an inexpensive internal drive and install it, or a external FW drive (OXFORD 991 chipset). the system drive contains the OS and the application .. to put audio onto it as well is just asking for trouble ... check out the compatibility docs at the DIGI website... read the manual on GETTING STARTED ...
ok, i remember hearin bout gettin an external drive. I was just rushin into it I suppose. Im not much of a tech guy (huge understatement). I had my Mbox and mic all set up n ready to go, hah. Thanks for the help though. I will be sure to go ahead and get another drive.
cannot be designated as an Audio Record volume because it is not a valid audio volume | Gav_Russell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-15-2016 03:52 PM |
Cannot be designated as an Audio Record Volume because it is not a valid Audio Volume | soloavenger | macOS | 7 | 02-15-2016 03:49 PM |
Session must be on an audio record volume if permmited set the volumes to R record | lionandthemouse | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-11-2013 01:48 PM |
hd cannot be designated as an audio record volume because it is not a valid audio | wapeddell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 04-12-2010 12:05 PM |
cannot be as an audio record volume because it is formatted as a FAT volume | rtm | Pro Tools TDM Systems (Win) | 3 | 12-18-2008 09:52 AM |
