Long Bounce Times with 2020.12
Since updating, offline bounces take a long, long time to prep before bouncing (at the expected speed), then hang again for awhile at the end of the bounce. It's so long that realtime bounces are actually faster for mixes of a few minutes or less. Anybody else seeing this?
Can't complain much, though, as I've actually found 2020.12 to be the most stable and error-free version on my system in quite awhile.
Custom i9-12900K, 64GB RAM, W10 Pro, PT Ultimate 2024.03, HD Native, OMNI, Digi 192, UAD-2 Octo; Mac Pro 12-core 3.46, 64GB RAM, Mojave, Logic Pro 10.5.1, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Mojave, MOTU 8-Pre-ES, Pro Tools 2021.7 |
Re: Long Bounce Times with 2020.12
Could it be a UAD issue? I have not noticed longer bounces, but I don't use UAD. I'm mostly Waves, Fab Filter, and other AAX plugs.
Steve
Steve Shepherd Extreme Mixing |
UAD does slow down offline bounces, but that has always been the case and this is something new. It's actually a minor annoyance, and since PT is running very smoothly otherwise I don't want to tinker too much. But if others are experiencing the same thing since 2020.12, it would good to know if it's a bug or a 'feature.'
Can you be more specific? What times are you pulling down. I just bounced a 5:30 song @ 6.7x speed
5K Retina 27" (2020) iMac OS 13.6.5 Ventura 3.3 GHz 6-Core intel Core i5 AMD Radeon Pro 5300 4 GB 64 GB 2667 MHz DDR 4 Internal 2TiB SSD Pro Tools 2024.3 EuCon 4.8.6.41 / 2023.11 UA Luna UAD 11 UA Apollo Twin X Avid S1 / Fire10 - 21.8.1.0 PreSonus DigiMax FS 8-input ADAT Dynaudio Monitors PreSonus Temblor 10 Sub Check my Music out here: Paul G YouTube Paul G Bandcamp |
It's not the bounce speed that has been affected, but the long prep time before the bounce actually begins. It's taking up to three minutes before it starts, then when the bounce finishes, the bounce dialogue stays on screen for another period of time. The wait time is definitely affected by the size and complexity of the mix, but even on simple stuff it doesn't start instantly like it used to.
I guess it depends on how many plugs you have. If you're getting good bounce speed (disk write) but the bounce is taking a long to coalesce, that tells me there is read latency. Try to get some metrics of your disk while you're doing the bounce. If you see high reads, it could be the plugs, or you may try trashing prefs... I mostly run Waves plugs, but have a few UA plugs on a session now. As soon as I hit opt/ctrl/b - it fires the bounce immediately.
Yes, any one outdated plugin may cause this. And obviously you would not notice if you did realtime bounces, until the blugin is so bad it stops bounce.
I do use Waves ReWire from time to time for Waves Tune, and I've got the current versions, but I'll check to see if it was in any of my recent projects.
But just to reiterate, this issue didn't appear until after installing 2020.12, it hasn't slowed the offline bounce speed, or caused any problems with realtime bouncing.
I had a big problem with this until I did this:
Uncheck this box in the Mix Bounce Prefs when you bounce a track if it's just audio. Don’t use Pad to Frame boundaries. It’s literally only necessary if you are going between Pro Tools and Media Composer or another NLE that is frame-accurate vs sample accurate. G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS |
large project long load times? | bassmagnetic | Post - Surround - Video | 10 | 05-14-2017 12:11 PM |
Ridiculously long hang times with PT10 | brianbotkiller | Windows | 1 | 04-25-2013 07:29 AM |
White noise after long idle times - Win 7 | mano111 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 05-05-2011 06:57 PM |
PT8 long load times | ergalthema | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-14-2010 01:41 PM |
Long Launch Times in 5.0.1 | [email protected] | Pro Tools TDM Systems (Mac) | 1 | 02-26-2001 07:57 AM |
