Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 11-18-2020, 12:52 AM
Sardi Sardi is offline
Default Re: Can someone please explain Ableton Link
Originally Posted by ratava911 View Post
Could someone give me the steps to do this... Sorry. This is documented absolutely nowhere! I have been googling for hours!!!
This is the software I was referring to.
https://rogueamoeba.com/loopback/
Old 04-05-2021, 11:37 AM
Mike Caffrey Mike Caffrey is offline
How do you enable Link in ProTools?
Old 04-05-2021, 01:58 PM
EdgarRothermich's Avatar
EdgarRothermich EdgarRothermich is offline
Here are three pages from my book "Pro Tools 2020 - How it Works" that explain what Ableton Link is and how to set it up in Pro Tools.
(Sorry for the low resolution, the images seem to get highly compressed when posted on this forum)
Edgar Rothermich
Author of "Pro Tools 2020 - How it Works"
from the Graphically Enhanced Manuals (GEM) series
http://DingDingMusic.com/
YouTube Channel Music Tech Explained https://YouTube.com/c/MusicTechExplained/
Old 12-02-2021, 08:13 AM
Markrosoft Markrosoft is offline
I think your answer is to sync the two DAWs via MTC and not using Ableton Link at all.
I'm looking to do the same thing as you... I think. And if I understand what you're trying to do, the problem with Ableton Link is that only links tempo and start/stop. I could be wrong, but from what I can tell, there is no timecode sync. So if you start your PT project at 1 minute, it would just start your ableton project wherever the playhead is in Ableton. That doesn't work for me.
But there is a solution that works! Synching the two programs via MTC and not Ableton Link.
Here's a youtube video I found that explains it very clearly:
https://www.youtube.com/watch?v=YEdS...el=JoeyMaguire
Following his instructions you can use PT as the Timecode Master and have your midi tracks running in Ableton. When you hit play on PT, ableton will start playing in sync with it. If you move to a minute into your project on PT and hit play, Ableton will play in sync with that. The only thing I'd add to his video is that in mac's Midi Studio, if your IAC Driver is grayed out, you'll need to double click on it and then check the box that says "Device is Online."
Of course you'll need to find a way to get your audio back into Pro Tools. For that you could use Loopback. Or you could just export the audio from Ableton, when you're ready, and then import that audio into PT. Both methods have their pluses and minuses, I think.
Not positive this is what you were looking to do but this does seem like a more comprehensive way to sync the two programs.
Looking for cool applications of Ableton Link ejinbc Pro Tools 2020 1 09-13-2020 07:17 PM
Ableton Link... Why So Cryptic? grayter1 Pro Tools 2020 9 09-06-2020 03:03 PM
PT 12 & Ableton (routing PT 12 into Ableton for using Sends) Feinbeat Getting Started 1 02-23-2017 10:31 PM
PT HD CORE & HD ACCEL + SSL Delta Link + SSL Alpha Link Noizz focushocuspocus Pro Tools TDM Systems (Mac) 1 09-29-2012 08:12 PM
Pro Tools Playback Issues at 88.2 with Delta Link / Alpha Link - Any ideas? azirkin macOS 1 01-17-2012 01:30 AM
