Old 02-21-2021, 01:31 PM
Dizzi45Z Dizzi45Z is offline
Default Re: "Select Assignments to" - Changed to show hidden tracks.
Originally Posted by reflexson View Post
Yeah this is unfortunate. When I can remember, I change the output path of a track I’m going to hide and make inactive to an unused bus. Really stinks.
That is a smart workaround. I’ll have to do that for now.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course
Pro Tools HDX 2023.9
Mac Pro 7,1 3.2 GHz 16-Core Xeon W
160 GB RAM
macOS 11.7.4
Noisebox Studios -Utah Recording Studio
Old 04-06-2021, 06:47 PM
SebTeti SebTeti is offline
Yes indeed but so annoying... Any updates on this ? Does anybody had tried to reach out to AVID ? I can't believe they did this without an option ... unless maybe it's a big and they gonna fix that in another update ?
Old 06-20-2022, 09:44 AM
Electronic1982 Electronic1982 is offline
Originally Posted by EdgarRothermich View Post
Correct. It worked fine in 2019.12
This is truly a terrible change, intentionally or just an oversight.
One solution is to have two select commands, with or without the Hidden Tracks. And also the other Restore command that is available in the Track List Menu
  • Select Assignments to ... (only Shown Tracks)
  • Select Assignments to ... (including Hidden Tracks)
  • Restore Previously Shown Tracks
Has this glitch been fixed?
Does anyone know how to restore the "Select Assignment to" so that it only selects the tracks without showing the hidden ones?
Thanks.
Old 12-27-2022, 02:50 PM
Default Bug PT-263050 "select assignments to" discussion
Hi all, I would like to talk about bug PT-263050 in Pro Tools
When selecting a tracks input/output to "select assignments to" ,
instead of selecting the tracks, a glitch keeps showing the hidden tracks (and then selecting them), and as a result,
it makes several tracks jump out (from hidden) which ruins the entire layout of the session, causing you the need to restore the track layout each time.
I've tried hiding the inactive tracks afterwards, but some of the tracks are active and need to be hidden and some are not.
The tracks just need selecting (like it did before), without showing the hidden ones.
I've found that the bug first started happening after Pro Tools 2019.12
(so version 2019.12 was the last time this bug was not happening)
This bug is making it difficult to see where buses/inputs/output are being routed, especially during large sessions.
I find myself trying to correct which tracks should be hidden and which tracks should be showing repeatedly because of it.
I understand there are bugs to fix, just this one ruins the consistent flow of the session for me and would really appreciate an update from Avid to fix it.
Any thoughts and comments would help as this bug is constantly on my mind.
Thanks for reading
Old 04-19-2023, 11:28 AM
This is bug PT-263050 and needs to be fixed
  #16
Old 04-19-2023, 02:31 PM
Agreed!
160 GB RAM
macOS 11.7.4
  #17
Old 05-22-2023, 08:23 AM
Default Re: "Select Assignments to" - Changed to show hidden tracks [PT-263050]
A possible solution could be to give 3 options when you Left-Click on inputs, outputs and sends:
1) Select Tracks (select assignments to)
2) Select & Show Tracks (select & show assignments to)
3) Show Tracks (show assignments to)
Please fix this
I would like to update but I can't
  #18
Old 05-22-2023, 08:31 AM
This won't work because some people hide tracks that are Active (and need to remain active), so it means the all the hidden tracks will still Jump out from hidden and destroy the layout of the session,
and now you have to look around find the all tracks that need to be hidden again and again, people can't work like this
  #19
Old 05-23-2023, 06:21 PM
I really hope they do fix this.
Another thing I do is every time I use this feature to "select assignments..." or "Show assignments..." I save a memory location that includes "Track visibility" Then after I use the feature, I recall that memory location.
This is a temporary way around it, but it would be so much better if this problem didn't exist.
160 GB RAM
macOS 11.7.4
  #20
Old 05-24-2023, 12:46 AM
Repeatedly having to interrupt the workflow with frustrating corrections and alterations throughout the session continuously effects your focus and creates a terrible workflow. Knowing where everything is routed is essential and needs to be presented to the user with ease (no additions needed), otherwise it's a constant reminder theirs problems
"Select Assignments to" is not working correctly! It shows the hidden tracks! Electronic1982 Pro Tools 2 06-20-2022 12:42 PM
Show tracks inside folders with folder hidden snowplaysmusic Pro Tools 3 06-22-2021 03:58 PM
After update hidden and inactive tracks show on s1\dock\control app ramonetl Avid S1, S3, Dock and Control App 7 06-26-2020 10:29 AM
select only assignments to brdst Avid S4/S6 1 11-05-2016 10:33 AM
No track assignments to hidden tracks! zoundsabar Artist Series 0 01-10-2011 05:12 PM
