Old 03-14-2010, 01:04 PM
elv1s1sal1ve elv1s1sal1ve is offline
Default Switching from Windows to Mac
I'm having trouble accessing my sessions that were done in PTLE for Windows on my Mac machine. I installed all the necessary Mac based software on my my new machine. Is it possible to setup the same audio drive I was using with my Windows device for use as my audio drive for the Mac system? I keep getting a few weird messages such as:
"This session is saved on a volume set to "Transfer" only. If permitted, set the volume(s) in question to "P" (Playback) or "R" (record) in the Workspace.
Otherwise, choose OK to save a copy of this session and its media to a valid playback volume. The session copy will automatically open from the chosen location."
If I go through those motions, it only allows me to save the "copy" to my Mac system drive. Then it opens the session, but when I attempt playback, I get:
"DAE error - 9035 encountered"
Can anybody get me headed in the correct direction to troubleshoot my issues? Thanks.
Gateway 7510GX, AMD Athlon 64 3700+ 2.39 GHz, Windows XP Pro, PTLE 7.3.1.123, MBox, 1 GB RAM, external Seagate 150 GB HD
Old 03-14-2010, 02:53 PM
Default Re: Switching from Windows to Mac
You should drag all your session folders onto some other drive and reformat the audio drive as described in the Mac part of the Getting Started Guide(I think its HFS+ with journaling enabled, but I might be wrong on that). Your drive from your PC setup is likely either NTFS or Fat32 and neither are sanctioned for the latest OS or Pro Tools). Once the drive is formatted correctly, drag the session folders back onto it.
Old 03-14-2010, 03:30 PM
Cool, I will try that. Thanks.
Switching to Windows? roberts Pro Tools TDM Systems (Mac) 6 02-15-2010 09:23 AM
Switching to Windows From Mac mftorso Pro Tools TDM Systems (Win) 14 07-21-2009 01:31 AM
Switching from Windows to Mac Pro Toonvox Pro Tools TDM Systems (Mac) 15 07-16-2009 09:44 AM
Switching from Mac to Windows stagegrin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-01-2002 10:52 PM
switching windows b tedeborg Pro Tools TDM Systems (Win) 4 03-16-2000 07:47 AM
