Old 12-21-2019, 04:11 AM
jamesleonard jamesleonard is offline
Default 003 control surface definitely works with Mojave
This MIGHT be my last post here as I have moved to Logic Pro X. However, I can absolutely CONFIRM to everyone - who has a 003 - that THIS DEFINITELY 100% WORKS in Mojave.
However it will not WORK in Catalina (as this is 64 bit architecture).
So you should have a 'dual boot' i.e.:
Logic Pro X/PT 2019.5/Mojave 10.14.5 (for 32 bit architecture)
Logic Pro X/PT 2019.12/Catalina 10.15 (for 64 bit architecture)
This is my set-up
Remember this:
On my old Late 2015 iMac i had a FW400 to FW800 (003), and I had this going into a Thunderbolt to Firewire adaptor. (iMac)
However, I now have the above set-up going into:
Thunderbolt 3 (USB-C) to Thunderbolt 2 Adapter (because I have a newer iMac with T3 ports.
The 003 is still a ******* fantastic machine, however, Catalina WILL NOT accept 32 bit architecture.
I have a Mojave volume (plus my Mojave data) and a Catalina volume (plus my Catalina data) – I can switch back and forth between them, no problem.
You cannot have a shared pool of data though. That could work for some applications, but the Apple applications don't play well.
Merry Christmas and a Happy New Year.
I'm outta here!
Last edited by jamesleonard; 12-21-2019 at 04:13 AM. Reason: IT WORKS PERFECTLY On MOJAVE
PT 2018.7 on MacOS 10.14 Mojave works for me veinticinco Pro Tools 2018 38 12-09-2018 07:35 AM
2018.10 works on MBP i9 with Vega 20 and Mojave DarkandKurious Pro Tools 2018 3 11-27-2018 12:23 PM
003 control surface (As audio) & control 24 as surface crizdee ProControl, Control|24, Command|8 7 01-04-2016 12:30 PM
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control lberrios1962 Pro Tools 10 18 05-26-2012 12:51 AM
Motor Mix only control surface that works w/PT AND Logic?!? pfd4 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-31-2003 11:00 AM
