Old 07-08-2019, 01:14 PM
fourthtunz fourthtunz is offline
Default falcon failed to load because it is not a valid 64 bit plugin
I was getting a 7054 error when I instantiated uvi falcon in the track
then download again from avid, then got
falcon failed to load because it is not a valid 64 bit plugin..
what gives?
The thing was it was loading but without presets and I finally got them on the Mac but now
I can't instantiate the plug so I can use it to find the files.
macbook pro 15" I7 2.7 2014 16 gigs ram Seirra 10.12.6
Protools 2019.5
ilok app up to date
Old 07-09-2019, 07:36 AM
Default Re: falcon failed to load because it is not a valid 64 bit plugin
solved!
removed the aax falcon plugin and reinstalled and now it works!
Load avid/presets to uvi/falcon every time kmusic AAX Plug-ins 0 12-06-2018 03:49 PM
Quicktime plugin Failed to Load Error DonaldM Post - Surround - Video 1 05-07-2018 12:21 PM
All the internal Avid plugins failed to load wescravn Pro Tools 12 15 11-15-2017 09:58 AM
PTHD 12: Quicking Wrapper Plug-in Failed to Load catsynth Pro Tools 12 0 04-23-2017 01:46 PM
Some UAD plugs "failed to load...not valid 64 bit AAX..." sfsonarboy AAX Plug-ins 3 02-04-2016 05:55 PM
