Old 08-12-2019, 08:43 PM
RGrierson RGrierson is offline
Default Re: having problems with pt10-HD3
Hyperthreading or virtual cores came along with the 2009 Mac Pro's
Sounds like you have a bad DSP on the HD Cards or TDM flex cable
Did you run the DigiTest app with all your interfaces turned on?
Is it Passing all the tests?
It could also be a TDM flex cable that needs to be re-seated since you moved the HD cards from one machine to the other.
New PT10 User Problems roaster42 Pro Tools 10 3 11-16-2016 10:11 AM
problems with PT10 after reinstall magnusn macOS 4 08-09-2013 05:03 AM
Migrating to PT9 - Too many problems using PT10 MadDogRunner Windows 0 05-24-2012 11:55 AM
VST Problems in PT10 hbhunt macOS 3 12-30-2011 07:14 PM
OT: TL Space-Problems in PT10 HD! lownotesinc Pro Tools TDM Systems (Mac) 1 11-07-2011 10:22 PM
