Old 11-10-2020, 06:23 AM
kava kava is offline
Default modules go offline
Everyday I notice 2 of my modules are going offline every day after some idle time (1x display, 1x fader) - a complete power cycle (cutting all power) is necessary to get them online again. I cannot just reboot them from the Surface tab.
is there some timeout on these modules that can be set individually? it seems to happen everyday after lunchbreak :)
any ideas?
Mac Pro 2019 16-Core, 144GB Ram, OS X 10.15
ProTools Ultimate, 2x HDX
NTP Penta720 I/O + 192 HD I/O + SSL Madi Link
Sync HD, Dolby Atmos RMU
S6 - M40 - 32channel.
Filmpost at cosmix studios vienna
http://www.cosmix.at
http://www.tom-kava.com
Old 11-10-2020, 07:10 AM
creativecontrol's Avatar
Default Re: modules go offline
Greetings,
If you touch those modules from the Settings > Surface page - do they have an IP address? If so, is it in the same range as all of the other modules?
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 11-17-2020, 07:31 AM
yes, their IP adress is in the same range as the other modules, just the status changes to Offline. I now observed that their status is somehow 'degrading'.
in the first hours of the day the module (in this case one of the fader modules) works fine. and after about 5 hours running. its reacting more slowly - pressing a mute button takes about 2-3 seconds to be executed in Protools. and then after one/two more hours - the same 2 modules go offline and the console has to be power cycled.
Old 11-17-2020, 11:45 AM
Do you have other NIC's on this workstation with IP's in the same subnet range by chance?
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 11-19-2020, 12:39 AM
Hi Jeff,
I have a seperate network on one of my ethernet ports (192.168.2.xxx) for the S6 and the Penta 720 Interface (using EuCon Monitoring) this network has no connection to the rest of the house (which runs on a 10.0.xxx net anyway)
I observed the behaviour again yesterday. after an uptime of 6-7 hours both modules start reacting extremely slow.
Rebooting the modules wouldn't be a problem, but a complete s6 power cycle during a mix with the client is not so nice.
tom
Old 11-19-2020, 12:46 PM
EddieJones's Avatar
I would try switching the Ethernet ports that those 2 go into the switch and see if the problem moves.
Offline bounce crash, probably Waves-related, and offline bounce not 100% correct Skwaidu Pro Tools HDX & HD Native Systems (Mac) 3 03-23-2015 03:55 PM
System 5MC, modules go offline very often Electrix030 System 5 1 11-04-2012 04:38 PM
PT9 + sound modules? Oroz Pro Tools 9 0 11-29-2010 09:16 PM
E-mu modules? VincePro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 09-19-2002 08:35 PM
Anyone know how much the SMM modules are? PTPerson ProControl, Control|24, Command|8 10 07-22-2000 09:00 AM
