Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 10-23-2020, 04:52 PM
danonbass danonbass is offline
Default Propellerhead Reason as instrument issues.
I've used Reason as an instrument plug-in in PT for quite some time, but I've been getting some issues recently. Reason won't open properly and I'll get the pinwheel of death. I'll have to force quit Reason, and often times PT as well. I thought it might be an update issue so I got on the newest versions. That has actually seemed to made the problem worse. Both programs work just fine independently from each other. Any clues as to what's happening?
PT 2020.9.1
Mac Pro (late 2013)
OS Catalina 10.15.6
16GB 1866 MHz DDR3
Reason 10.4.1d4 (build 10,700)
Old 10-23-2020, 05:49 PM
Sardi Sardi is offline
Default Re: Propellerhead Reason as instrument issues.
Just to confirm, you’re using Reason 10 so you’re not actually using it as an instrument, you’re using it standalone linked via ReWire.
If I have that correct, ReWire has been deprecated since v11. I would have thought it would continue to work on your version, but seeing you’re running the latest Pro Tools and Mac OS, I’m going to say it’s a ReWire issue.
Since v11, you can run Reason as an actual AAX plugin directly within ProTools. Unless there’s something specific to the app itself you want to continue to work with, I’d suggest looking at upgrading and using it directly within PT.
Old 10-23-2020, 06:43 PM
Yep. An upgrade to Reason11 did the trick. Thanks!
Propellerhead's Reason getz76 Pro Tools 10 4 03-22-2012 08:29 PM
Propellerhead reason 4/ Record fix!!! iamstress 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-03-2010 06:06 PM
Reason by propellerhead! Benjamino General Discussion 0 06-10-2005 01:18 PM
Digi and Propellerhead Reason Again tradinjfoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-06-2002 07:01 PM
Digi 001 and Propellerhead Reason? jack-dangers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-24-2001 12:29 AM
