Samplecell Users Front End?
Any help is much appreciated... I would've posted in the SampleCell section, but it's essentially dead.
Hi... I've just added a samplecell II card to complement my others (mainly drum triggering purposes). My question to you power users... Which program should I use as a "front end" to get all my AUDIO sample CD's into the right format. I'm undergoing a large transformation of all my drum libraries (unfortunately all on audio only CD's) into the right format for Samplecell. Do I use something like Toast Audio Extractor to convert all into SDII files, or PEAK? I'll be xfering 1000's of hits, so I need something fairly intuitive but deep enough for serious cataloging. Also, I'm a little confused as to whether I should be converting everything to Stereo SDII files (for other future uses too) or to split SDII files? Thanks in advance for any insights... |
Re: Samplecell Users Front End?
Gallery Samplesearch. Long in the tooth (like Samplecell!), but unique and powerful!
One follow up if I may... Should I be converting individual hits/pads to SDII STEREO files or SPLIT stereo files? |
Make stereo files.
They're easier to handle and edit. Also there's less chance that the channels get out of phase during playback. The last time I transferred samples from an audioCD to a HDD library i simply recorded the whole CD to two tracks in PT. Then it was easy to create and name a region for each sample (bd01.L, bd01.R etc). When that's done I just selected all and exported the regions as 16 bit stereo files. [email protected] |
The last time I transferred samples from an audioCD to a HDD library i simply recorded the whole CD to two tracks in PT. Then it was easy to create and name a region for each sample (bd01.L, bd01.R etc). When that's done I just selected all and exported the regions as 16 bit stereo files. [email protected][/B][/QUOTE] Nice tip.... Thanks.... any others out there? |
mbox users: suggest good front end (mic pre & A/D) | goldenechosMS | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-05-2004 07:45 AM |
Great deal for SampleCell users... | tld | Tips & Tricks | 21 | 02-26-2002 12:11 AM |
Any Soft Samplecell users out there? | CCash | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 02-12-2002 06:05 AM |
Soft SampleCell not compatible with SampleCell 2 | P BUCKLE | Pro Tools TDM Systems (Mac) | 11 | 06-06-2001 10:24 AM |
SampleCell II PC spec & access to samplecell CDs | Dewi | Digidesign Hardware & Software | 0 | 10-24-1999 10:32 AM |
