Old 02-28-2001, 10:38 AM
village1 village1 is offline
Default any way to get lead vocal softer during mastering?
The good news is that I'm working with a great singer. The bad news is that I may have fallen in love with her voice and put the vocal to far up in the mix. Is there any way during mastering to get the lead vocal a bit softer relative to the band
without having to go back and mix it all again? I'm using t-racks for mastering.
Thanks,
Giovanni
Old 02-28-2001, 10:55 AM
IOP Drummer IOP Drummer is offline
Default Re: any way to get lead vocal softer during mastering?
Some compression and EQ might work, but might not work within your limitations....what I mean is you can do it but it might not sound so good. There would have to be compromise, but then again I have not heard the mix. Here's a helpful tip I learned from Jeff Poe (engineer of Santana/vanessa williams/guns and roses, etc.) When mixing, do a vocal+instrumental mix, a vocal UP+ instrumental mix, a vocal DOWN + instrumental mix, and an INSTRUMENTAL ONLY mix and finally a VOX ONLY mix. Remember, you have Pro Tools, and you can line up the vocals again if need be. (For example if it's mixed don to DAT, or any other outboard media.) If the mix took a long-ass time, do a whole bunch of stem bounces. Drums only, rhythms only, etc. Some mixes just happen, and it would be a shame to lose that uniqueness, fatness, and balance because the vox is 2dB too loud. Good luck, and hope the advice prevents potential problems for all in the future!
Mike Blanchard
Engineer
Old 02-28-2001, 03:06 PM
Corey Shay Corey Shay is offline
Use the Waves S1 plugin. You can decode the mix to M-S, and then if you don't want the bass to lower with the vocal eq the M channel so that the vocal range goes down while leaving the bass intact.
Old 02-28-2001, 04:52 PM
billrog billrog is offline
You could try using a multi-band compressor plug-in with selectable crossover points (eg McDSP MC 2000), find the exact band where the vocals sit and you will be able to reduce the vocal level and compress it to taste as well.
Bill.
billrog
Old 03-05-2001, 03:44 AM
Zep Dude Zep Dude is offline
From a purely EQ standpoint, if you add more low end (assuming your mix can take it), pull out a little presence (3k to 5k) and play with the Q to find the right "notch" you will effectively reduce the vocal. It's your judgement if this is adversely effecting the mix. Also, a multiband compressor set up to notch out the presence freqs might do the trick.
Good Luck
Angelo Montrone
Majestic Music
Studio / Label: www.majesticmusic.com
Old 03-08-2001, 07:03 AM
gh10606 gh10606 is offline
Just curious: did you mix in ProTools? If so, did you save your mixes? Why not just go back in, leave everything else the same, and turn down the vocal a little bit?
I know I'm being a bit obvious here, but I just couldn't stop thinking about it as I was reading this thread. One of the main reasons I bought ProTools was its totally recallable mix automation.
Good luck,
Glenn
Processing the modern lead vocal scrnplyr Tips & Tricks 35 09-26-2013 03:40 AM
Suggestions on tracking lead vocal Keefriffhard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-24-2005 10:47 AM
Lead Vocal Plug In tomhartman Pro Tools TDM Systems (Mac) 27 07-23-2003 07:13 AM
In your face stereo lead vocal.... Anthemmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 03-15-2003 11:25 PM
Lead vocal question richie rich 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-31-2003 11:54 AM
