Old 03-06-2001, 01:10 PM
bradleyb bradleyb is offline
Default Samplecell Users Front End?
Any help is much appreciated... I would've posted in the SampleCell section, but it's essentially dead.
Hi... I've just added a samplecell II card to complement my others (mainly drum triggering purposes).
My question to you power users... Which program should I use as a "front end" to get all my AUDIO sample CD's into the right format. I'm undergoing a large transformation of all my drum libraries (unfortunately all on audio only CD's) into the right format for Samplecell.
Do I use something like Toast Audio Extractor to convert all into SDII files, or PEAK? I'll be xfering 1000's of hits, so I need something fairly intuitive but deep enough for serious cataloging.
Also, I'm a little confused as to whether I should be converting everything to Stereo SDII files (for other future uses too) or to split SDII files?
Thanks in advance for any insights...
Old 03-06-2001, 07:04 PM
Bryan Bryan is offline
Default Re: Samplecell Users Front End?
Gallery Samplesearch. Long in the tooth (like Samplecell!), but unique and powerful!
Old 03-06-2001, 09:45 PM
Thanks Bryan. I checked out there web site and the software looks pretty powerful.
One follow up if I may... Should I be converting individual hits/pads to SDII STEREO files or SPLIT stereo files?
Old 03-07-2001, 02:09 PM
ballerina ballerina is offline
Make stereo files.
They're easier to handle and edit. Also there's less chance that the channels get out of phase during playback.
The last time I transferred samples from an audioCD to a HDD library i simply recorded the whole CD to two tracks in PT. Then it was easy to create and name a region for each sample (bd01.L, bd01.R etc). When that's done I just selected all and exported the regions as 16 bit stereo files.
nils@ballerina.nu
Old 03-07-2001, 02:34 PM
nils@ballerina.nu[/B][/QUOTE]
Nice tip.... Thanks.... any others out there?
mbox users: suggest good front end (mic pre & A/D) goldenechosMS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-05-2004 07:45 AM
Great deal for SampleCell users... tld Tips & Tricks 21 02-26-2002 12:11 AM
Any Soft Samplecell users out there? CCash 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 02-12-2002 06:05 AM
Soft SampleCell not compatible with SampleCell 2 P BUCKLE Pro Tools TDM Systems (Mac) 11 06-06-2001 10:24 AM
SampleCell II PC spec & access to samplecell CDs Dewi Digidesign Hardware & Software 0 10-24-1999 10:32 AM
