Old 11-09-2009, 10:29 AM
lbl lbl is offline
Default Waves Issue In Pro Tools 8
Hi All,
I protools will not launch fully after installing waves 7. I get a message asking to locate waves plugin 6.1.1 folder. I have seen the statement below by Digi but my question is which folder is the Waves Plug-ins folder located in to and make the Alias??
Thanks
When launching Pro Tools, the Waves dialog "Where is the Waves Plug-Ins folder?" may pop up behind the Pro Tools splash screen and may become inactive after bringing it to the foreground.
To solve this issue:
1. Right click on Waves Plug-ins folder and make Alias
2. Rename created "Alias to Waves Plugins" (capitalization is very important) to : Waves Plugins
3. Copy alias (to clipboard)
4. Go to ~/Users/Current User/Library/Preferences/
5. Create new folder and name it Waves Preferences
6. Paste Waves Plugins alias(from clipboard) into created folder (Waves Preferences)
7. Delete alias that you created in step 2
8. Start Pro Tools
The Light
Old 11-09-2009, 10:47 AM
Plug-In Plug-In is offline
Default Re: Waves Issue In Pro Tools 8
Really the best way to solve this problem is to throw away the waves folder from your applications folder and reinstall waves. That always fixed it for me. This work around sometimes works, sometimes it doesn't.
Hope that helps
Old 11-09-2009, 11:22 AM
crizdee's Avatar
crizdee crizdee is offline
Hope that helps
No, the best way is to remove all v6 waveshells from your pro tools plugins folder! library/app support/digidesign/plugins
Chris
Producer, Engineer,
www.ukmastering.com
Old 11-09-2009, 11:45 AM
ronwasserman's Avatar
ronwasserman ronwasserman is offline
Remove everything from the application folder, components folder, digi plugins folder, vst folder, user/library/preferences and user/library/caches.
Everything related to waves only (obviously) THEN install V7.
Ron Wasserman
http://www.ronw.com
http://www.imdb.me/ronwasserman
http://www.fishertheband.com
Mac Pro (Late 2013) 3.5 GHz 6-core Intel Xeon E5 - 32 GB Ram / 1TB Flash Storage - Avid HD I/O - Latest Mac OS - HDX3 - Latest PT Version.
Old 11-09-2009, 09:35 PM
lbl lbl is offline
Thanks guys, I will do as adviced and report back.
The Light
Old 11-10-2009, 12:53 AM
crizdee's Avatar
The reason you are being asked to locate the waves v6 folder is because you have a v6 waveshell in your plugins folder! simply remove the v6 waveshells and make sure only waves v7 waveshell is in your folder and it should be fine.
Chris
Producer, Engineer,
www.ukmastering.com
Waves plugins issue sirtunez Pro Tools TDM Systems (Mac) 8 02-16-2012 03:30 PM
Waves issue Frank of Denmark Pro Tools TDM Systems (Mac) 0 08-25-2009 07:25 AM
Waves SSL issue philrecords 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 08-18-2007 12:16 PM
one waves issue sorted, now for the other...... crizdee Pro Tools TDM Systems (Mac) 4 03-30-2007 05:13 PM
Does anyone else have this Waves issue? Mark Wheaton Pro Tools TDM Systems (Mac) 3 05-26-2006 03:20 PM
