Old 05-01-2007, 09:58 AM
NBASE NBASE is offline
Default Pro tools Latency!
I have a digi 002 system and I am running 7.3. I have been recording guita from Mic 1/Line 1. No matter what I do, there is still a annoying Latency there that I just cant get rid off. Its throwing my timing off. I tried Decreasing the buffer size down ridiculously. Seems to help a little but not that much. There are no effects running its input cleanly into the track. I dont know what to do any ideas. Every time i record o a click or a drum ot comes out wrong and subtly out of timing.
Old 05-01-2007, 10:04 AM
jre3132 jre3132 is offline
Default Re: Pro tools Latency!
have you tried low latency monitoring?
Mac Pro 3.7 Quad Core Intel
Mac OS X 10.13.2
PT Ultimate HDX 2019.10
64GB RAM
HDX I/O 16x16 Analog
HDX I/O 8x8x8
Old 05-01-2007, 10:06 AM
rallycars rallycars is offline
I record my guitar amp using an original mBox. Since I can hear what I'm playing, i turn the knob on the mbox all the way to playback and mute the recording guitar track to avoid any latency affecting my playing. Not exactly the same situation, but maybe it helps.
Old 05-01-2007, 10:16 AM
Jim Casey Jim Casey is offline
Low latency monitoring is mandatory as is a clean signal path, make your plugins inactive, especially the master fader and the track you are recording to - and do not have any analog send/returns active.
The other thing to consider is that you will always have some latency on the LE, the hardware isn't up to no latency, just low. So, in addition to playing hard on or ahead of the beat and making damn sure you record with a click (otherwise you have double latency) I will move the track (or sections of it) a smidge to the left or right in Slip mode. Just magnifiy in good and move it - sometimes you can tell from the waveform where your downbeats spike so make sure they hit on the lines (or between the lines or whatever your timing is) and you're good. One time I wanted a solo to really lay back so I moved the whole thing a little left of the beat.
Casey
You can hear what I'm doing at:
http://www.reverbnation.com/jimcasey
Old 05-02-2007, 11:48 AM
Thanks guys will give a try. Just thought there was a easier way to avoid it totally.
Old 05-02-2007, 11:54 AM
also watch out for reverb on the master or other channels - the pre-delay setting on the reverb will also add latency which will throw you off
Casey
Old 05-02-2007, 04:55 PM
Craig F Craig F is offline
there is, it's called HD
Thank you,
Craig
Pro tools SE Latency AnnoyedSE Pro Tools SE and Essential (Win) 6 03-13-2013 05:41 AM
How Can I Get Rid Of Latency In Pro Tools Le? R.O. Post - Surround - Video 3 12-05-2011 03:17 PM
Pro Tools 9 Latency... akhafaji Pro Tools 9 10 02-01-2011 02:48 PM
Low latency in Pro Tools 7.4 felix822 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 08-20-2008 05:46 PM
Pro tools latency obsuleet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-11-2007 12:04 PM
